450rwhp on engine + 150 dry = What injectors?
The car is finally going in to get tuned this month and I just wanna make sure i have enough injector for my application upon going to the dyno. (currently have 30#'s) The engine should make around 450 to the tires on HP, then im going to shoot a 150 dry. Will 36#'s cut it? Personally i think it would be asking for too much from the 30#'s. Thanks to all that help!
eventually it will be a dual stage setup. 100dry on the first stage and 150-200 on the second via direct port, fuel system, controller, ETC. But, thats going to be an expensive setup and i want action now! Hence my spare dry kit, ha. 70% duty cycle isnt all that bad IMO. I will be primarily a motor car, and spray when its time for business. Soo assuming the 36's hit 90% DC on the gun, its only for a few seconds, otherwise its way less when running on HP. Clrearly, based off your numbers, my 30#'s will go on ebay tomorow! Thanks for the reply!
anyone else have some good info?
yea the car has a cell, A1000, pre and post Aeromotive filters, Aeromotive FPR, -8 feed and return. Should support plenty! Then the direct port kit when i finally build it, will have its own cell with c16 and another A1000 as well.
At 575rwhp and 665rwtq, both highs on different pulls, my SVO 42's just barely were touching 80% DC. That was running rich also, about 10.5/10.8 area. So, I believe realisticaly that 700hp could be supported, and am going to find out real soon the new 408 with a 300rwhp shot, oh and the above numbers were a 250/285rwhp shots both in dual stage, new set-up 3-stage all dry. The math for getting a general idea on paper is in the wet vs dry thread if ya want to try that method.
Robert
Robert
Originally Posted by AshWS6
42s will feed enough to go 9.7s at 3600 lbs all thru the injector in a nitrous car
I have done 740 rwhp thru a 6 speed with 42 lb injectors, walbro 255 intank, hotwire kit and casper voltage balster on several different cars. Injectors where just about maxed out but AF was in the 10.8-11.2 range
That was also with stock fuel rails and stock feed lines, stock fuel filter.
Its a combo that I have used over and over with great success to hit the 700 rwhp mark. I am about to copy it yet again on my newest project car.
