How much N2O in HP can 3AN line flow?
Ls1tech & Truck Sponsor
-Garrett
So you (NX) are saying that a 3an line is not bigger than a 62 jet. On my system a 62 jet is a 150 shot. My 250hp kit came with 3an lines from the noids to nozzles. By just looking inside at my 3an line it looks much bigger than a 62 jet. The 250 jet is an 88 jet and the 3an line looks a little bigger than that. What is the size of a 3an line, jet size terms?
the issue is the orifice on the inlet side of the 3an insert of your line...it is larger than a .062 but not by much...the part # NX listed uses a 4an insert that is machined to accept a 3an nut to allow it to be connected to a standard jet fitting.
Most nitrous companies offer a similar line. And they all will likely be willing to make you a custom length if asked
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Most nitrous companies offer a similar line. And they all will likely be willing to make you a custom length if asked![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
-Garrett
