Is timing tuner the only option to control timing on the fly?
Old Jul 3, 2007 | 10:49 AM
striker754's Avatar
Default Is timing tuner the only option to control timing on the fly?
Is this the only option to cut out timing for nitrous besides permanently removing it from the pcm file?
Old Jul 3, 2007 | 11:41 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
No...MSD makes a TIming Twister for the LS1 and LS2 platforms
Old Jul 3, 2007 | 11:49 AM
Cam72aro's Avatar
True, but with the msd it doesnt have a built in window switch.
Old Jul 3, 2007 | 12:28 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
I realize the timing tuner has a built in window switch....but he was asking if it was the only option for timing retard.
For the LS2 the timing twister is the only option I know of
Old Jul 3, 2007 | 01:00 PM
striker754's Avatar
looks like timing tuner is cheaper and has a window switch in it.
Old Jul 3, 2007 | 01:02 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
thats why we stock the timing tuner
Old Jul 4, 2007 | 03:53 PM
Cam72aro's Avatar
I am sorry. I didnt realize thats what he was asking. I just know that with the timing tuner you get more bang for the buck.
Old Jul 4, 2007 | 05:01 PM
BriancWS6's Avatar
If your running a dry kit, there is a way to pull timing only when your spraying. The rest of the time you will have your normal max timing for all motor runs.
Old Jul 4, 2007 | 07:38 PM
BigDB's Avatar
Will the timing tuner work on a 402 build? It uses a LS2 block but the LS1 electronics are there, only difference is the knock sensor placment I think, is that the problem?
Old Jul 6, 2007 | 09:35 AM
Matt@HSW's Avatar
As long as you are using the LS1 crank position sensor it should work (and a 24 tooth reluctor wheel on the crank). I heard there is another option coming out that will work on both the LS1 & LS2 platforms that looks pretty promising.
Matt
Old Jul 6, 2007 | 07:24 PM
snowbird88gta's Avatar
I believe this is done with a tuner such as HPTuners and it happens due to the IAT. Robert or someone else with knoledge on this subject can chime in but I'm pretty sure that this is correct.
