Heater problems/questions
My question is....How long does it take for a heater to get warm. I waited for about 3 minutes and didnt feel any difference on the heater. Do i need to wait longer for it to start working?
Thanks
Check your switch pinouts. Take the switch out and it has a sticker on the back that tells you what goes were electrically. The center I think goes to the relay, the top I think is your switched +, the bottom I think is ground.
When you activate the switch use a test light and see if the power is getting to the relay. If it is then your trouble is in the relay, check that wiring next.
Beer
Thanks
Do you have a NOS kit with another relay? If so swap out the relays and see if it works then.
Make sure you have 12v going to the white wire on the element
Also are you running a adj pressure switch with this? You cant use both the thermostats and the pressure switch together. I tried and had problems with heating the element until I talked to Kyle@NOS
Beer
Could not running a thermostat cause the heater to not work?
BTW...i'll have to play around with the relay. Maybe its wired wrong but i dont think it is.
Pin 85 to Ground
Pin 30 your Fused + supply (nice thick wire)
Pin 87 to one wire of the heater element, the other heater element to ground.
I'm going to try and get it working tomorrow.
