Test noids???
Old Jul 20, 2007 | 07:30 PM
2002RamAir's Avatar
Default Test noids???
Hello all,
Is there anyway I can test the noids and make sure they are working correctly??
Also, Is there anyway I can test the window switch to make sure its working right?
All of this I would like to do without the nitrous hooked up...Just wanna do a test so I dont blow anything up.....
Thanks
Old Jul 22, 2007 | 09:50 PM
JohnFrazee02SS's Avatar
yep ground the noids and then touch the pos terminal and it should click if not call ray at nitrous outlet
Old Jul 22, 2007 | 10:02 PM
BayAreaSS's Avatar
Thats how i did it. The click was a lot louder than i expected.
Old Jul 22, 2007 | 10:28 PM
1ORANGEWS6's Avatar
I take a 9 volt battery to test my solenoids.
Old Jul 22, 2007 | 10:50 PM
2002RamAir's Avatar
Any idea how to test the window and make sure all is good with that?
Old Jul 23, 2007 | 01:10 AM
Zero4488's Avatar
Restricted User
Not really sure how to test the window switch, I guess you can put the rear on jack stands and put the car in gear and see if it all works...thats about the best answer you'll get out of me...lol
Old Jul 23, 2007 | 01:27 AM
Breaking Stuff's Avatar
I would disconnect the nozzle and tape it to the inside of a bottle or something. Bring the car up to where your window switch is set to, and have a friend hit the micro switch. If you want to test the individual solenoids at the same time get 2 bottles and tape each line to them. You dont want lines flying around and spraying fuel all over your engine bay.
Old Jul 23, 2007 | 09:24 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
you can also set the activation point to 1500-2000 rpm...bypass the WOT activation....rev the car to the activation rpm with the car in neutral and the solenoids should click
Old Jul 23, 2007 | 09:25 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
yep...this works well
Old Jul 23, 2007 | 03:54 PM
algws6's Avatar
beware, just because the noid clicks does not mean its working. the fuel noid will still click even if the plunger is swelled shut. i disconect the fuel line, put it into a bottle and ground out the relay. takes 2 minutes and gives you piece of mind.
Old Jul 23, 2007 | 05:12 PM
Black99TransAm's Avatar
this is all good info... this should be added to the facts and questions section. because i was just reading up on this
Old Jul 23, 2007 | 05:17 PM
Sharpe's Avatar
