dual nozzle or plate kit
Old Aug 4, 2007 | 11:32 PM
ssfast99's Avatar
Default dual nozzle or plate kit
i picked up 7 mph with a NOS wet 100 shot and wanted to up the shot to a 200-250 shot. i was curious if it is better to go with a plate (throttle body spacer) or just Y off the sileniods and run dual nozzles like the TNT nitrous ring. also curious about the NX maf kit. just wondering which kit is better to plug into my existing NOS wet universal kit with the soft 90 degree nozzle.
Old Aug 5, 2007 | 07:49 AM
h777's Avatar
i'm running a Nitrous express dual nozzle wet setup, a 100hp shot gave me an extra 11mph in the 1/4 mile, dual nozzle setups give better distribution of the nitrous for a little more performance over a single nozzle
Old Aug 5, 2007 | 09:00 AM
BayAreaSS's Avatar
I would do a plate over dual nozzles
Old Aug 5, 2007 | 11:37 AM
Black2001z06's Avatar
Plate system for the win!
Old Aug 5, 2007 | 11:38 AM
Robert56's Avatar
They will both give the same results. The dual nozzles can be a cheaper route, and the plate a cleaner look. However, many do very trick nozzle set-ups also.
Robert
Old Aug 5, 2007 | 01:58 PM
WutupYo's Avatar
whats the benefit (if any) one has over the other, aside from cosmetics?
Old Aug 5, 2007 | 10:36 PM
ssfast99's Avatar
thanks guys but i am interested in what is better for the engine. also h777 11mph is pretty good. i need to tune my car for nitrous now.
Old Aug 6, 2007 | 06:40 AM
h777's Avatar
11mph is without a tune, i will be spraying a 200hp shot soon with a tune looking for a 10 second run,
Old Sep 22, 2007 | 04:22 PM
Dragman's Avatar
on a 150 shot what would be quicker plate or nozzle?
considering everything the same as in AFR.
Old Sep 22, 2007 | 07:00 PM
Robert56's Avatar
Same.
Robert
Old Sep 22, 2007 | 10:01 PM
jmill96Z's Avatar
What weighs more 15lbs of bricks or 15lbs of feathers?
A 150 shot is a 150 shot. The differences are cost and appearance. I guess if you wanted to really get down to it, you could look at the length of the lines from the noids to the plate/nozzle to see how hard it would hit.
Old Sep 22, 2007 | 11:14 PM
5_02ls1's Avatar
well im assuming you are runnin the same nos universal wet kit i am using.....It is a flywheel rated kit.....the nossle that comes with the kit is good to a 150 fwhp shot.....some of the plates are rated at the wheels so id say the plate would be better.....
hmmm the noids im not sure on i think there rated to 200 flywheel i could be off on that though...........m thinkin of puttin a t in my n20 solenoid and doin a 75 mass air shot....you may wanna consider somthing like that..........adding another noid of course
Old Sep 24, 2007 | 03:56 PM
Dragman's Avatar
tested it plate was slower than NOS soft plume nozzle with same jets and AFR.
