Stand Alone Question?
Old Aug 17, 2007 | 09:45 AM
02Z28's Avatar
Default Stand Alone Question?
I have a HSW stand alone setup for my nitrous kit, and I was wondering what pressure you guys set yours at? I'm going to be running a 100 to 150 shot.
Old Aug 17, 2007 | 10:29 AM
Chris@NitroDaves
Guest
Posts: n/a
Is your jetting for low or high pressure?
-Chris
Old Aug 17, 2007 | 10:32 AM
02Z28's Avatar
Its a TNT F2 kit... not to sure if it's high or low. I'll check and see.
Old Aug 17, 2007 | 10:34 AM
Matt@HSW's Avatar
Unless you swapped fuel jets on your TNT kit you'll want to swap the spring for the high pressure and set it for 58 psi. If you changed fuel jets you'll want to set the FP to match the new jetting.
Matt
Old Aug 17, 2007 | 02:43 PM
02Z28's Avatar
I haven't swapped the jets, so I guess I need to change the spring then.
Old Aug 18, 2007 | 06:11 PM
SILVERZZ28's Avatar
Low pressure is best. You can tune it easier. Plus its not hard on the pump
Old Aug 18, 2007 | 09:49 PM
02Z28's Avatar
So if I get the jets for low pressure, I could run the lower pressure spring? Where would I get them?
Old Aug 19, 2007 | 11:51 AM
Matt@HSW's Avatar
Yes, you could try TNT for the jets.
Matt
Old Aug 19, 2007 | 12:25 PM
monkey11's Avatar
ok, hate to steal this thread but i have a question for you guys with a stand alone! i plan on getting the one were the battery would go, but i also dont want to move the battery to the trunk! i planned on buying the small odessy battery but not sure were i could mount it? i know sounds some what stupid but my problem is that im still in IRAQ! So, just wanted to see if some one has done this already???
oh, i like the fact that it hold a gallon, thats also why i didnt want the one where the fuse box is at. ok thank alot guys.
Old Aug 20, 2007 | 08:49 AM
TNTramair's Avatar
hsw holds just shy of a full gallon..just FYI.
