Help, new to nitrous...
Old Aug 25, 2007 | 05:01 PM
candidate zero's Avatar
Default Help, new to nitrous...
Ok, I'm looking into ordering a nitrous kit for my car. It's a bolt-on LS1 M6, and I want to do a 100 dry shot. Will I be ok with the stock fuel system?
I plan on getting a Dynotune kit, with a MSD window switch, and some kind of FPSS.
Reccomendations, advice, anything?
Thanks everyone!
Old Aug 25, 2007 | 08:35 PM
LVCTSV's Avatar
Thanks everyone!
Do you plan on ever upgrading the system or running more than 100??
Old Aug 25, 2007 | 09:26 PM
Possibly, but not very soon.
Old Aug 26, 2007 | 12:30 AM
donkey mule's Avatar
With a dry shot I would upgrade the pump and injectors. With a wet shot I think you would be fine.
Old Aug 26, 2007 | 12:18 PM
LVCTSV's Avatar
Thats why i asked..because wet systems generally are much easier to upgrade...chances are you might want to up your shot since you get used to everything you know....
Old Aug 26, 2007 | 12:32 PM
oner's Avatar
Thanks everyone!
Both wet and dry kits are effective if your a/f ratio is up to par. If your going to run 100 dry shot I would upgrade injectors to 36lbs and, like said before, a fuel pump just to make sure you have adequate fuel. Then tune it and give em' hell.
good luck
Old Aug 26, 2007 | 02:26 PM
Ok thanks for the info everyone.
It looks almost as if a wet shot is a better choice, but I keep hearing the LS6 manifold has fuel puddling problems...time to search!
Old Aug 26, 2007 | 07:44 PM
sprydncamd ta's Avatar
i spray a wet 250 shot with no problems or puddling problems
