Biggest shot ever?
LS1Tech Co-Founder
Hacker Joe sprayed 250 or so back in 1999 to be the first LS1 in the 10's.
It was fine on 110, but he then had a brain fart and sprayed it on pump gas. It's neat to hear a motor that runs with only 7 pistons in it.
I think 200 with good fuel and tune is doable.
My set-up can go from 150 to 600 with a total of 3 stages. I have it set-up for a 150 in 1 stage when it goes on the car. I might try going 200 one time and see how it likes it. Will keep everyone updated.
personally, i've done a single 200 successfully. i tried a 100 dry/ 150 wet and fell over in the 1/8 mile. switched to a 100 wet/ 150 wet and same thing happened. worst i've done is melt a couple of plugs.
took the motor apart and still looked brand new. new bearings and rings and lives on in another car with a 180 direct port attached to it.
Ran the end of '06 season @ 250rwhp shot in dual stage, and the begining of '07. This along with accumulated 200+ passes (variuos size hits) on BONESTOCK longblock LS6. The death blow came on a dyno day shoot out where we sprayed 285rwhp dual staged shot and a ringland gave out (did win the top honors for best numbers though, lol). These motors can really take a beating and keep on running given tune parameters are spot on. Video of the dyno death run in ls1tech vids.
Robert
Robert
Originally Posted by jetblast
so 200wet all in one stage is doable with 100oct, with 12deg out for safty. 11.5afr and tr6 or 7?
Robert
i'm spraying my 100 at 4k right from the start ,launching at 6k, and delaying it .1 and finish it off .3 later starts at 80% to 100. i got lpe fuel pump, and i log all my runs. if i do a 200 i'll try to do it once in a while. is the stuff i got for fuel enough for a 200? for me the challenge is keeping it together for 2 seasons, after that i'll take out and stroke it and forge it. you were running very agressive timing when she broke on the dyno right?
Robert
