427ci w/100 shot vs. 346ci w/200 shot
With all other conditions being the same, whats a more ideal setup? What would be faster and trap higher?
346ci head/cam 450rwhp + 200 shot = 650rwhp
427ci head/cam 550rwhp + 100 shot = 650rwhp
Basically what I'm asking is whats generally faster, big cubes with small shot or small cubes with big shot. I know its a tough question, but I'd like to see everyones thoughts.
I think the OP wants to know if one will have a better ET than the other.
I would say the NA car would run a faster time, unless going up against someone spraying off the line. Normally, you spray (in street cars) past, like, 3000 RPM. If he's spraying off the line, then it would be a wash, I suppose.
Just speculation from someone with a stock-like NA car who's never driven a N20 car.
You could set up both motors to make the same rwhp, but the bigger motor will make more torque.
The bigger motor will also have more power potential.
The bigger motor can make the same power at less rpm.
427 is the way to go.
H/C 346 = 450rwhp/ 415ish rwtq
427 = 550rwhp/ 525ish rwtq
My friends H/C s197 with a 100 shot went from 340rwtq to 550rwtq on the dope.
So is a 100 shot is good for about 200rwtq, then a 200 shot would be a little more that 300rwtq?
But nitrous is a torque monster, wouldn't the torque from the 200 shot be able to meet the 427's 100 shot or at least get close?
I believe the small motor would be faster. the 200 shot of nitrous would put the 427's torque to shame. The bigger shot of nitrous on the small motor would give it more torque and hp throughout the entire rpm range.
One of the magazines did this with a 355 and 406 a long time ago and the 355won because of torque from bigger nitrous hit. Used same car and drivetrain for the test. Its been about 4 years ago since I read it.
i would also say go with the 427, the less gas you have to throw at it, the longer it will live. not saying that a motor with a 200 shot cant live a long time, it will just be easier on the bottom end with the 427 and 100 shot.....then agian you can always spray the 427 with the 200 shot too
