Got Traction?
Old Nov 8, 2007 | 09:30 AM
newtoLS1s's Avatar
Default Got Traction?
Over in the tire section the thought is that a 27" tall tire is too much for a stock geared M6, what are yalls thoughts being that this car is going to be run on the bottle? I dont think they are takin that into account over there. What size tires are the nitrous guys runnin? I've got LCA Relo brackets that are goin in too.
Thanks
Dave
Old Nov 8, 2007 | 03:10 PM
josh2002-ws6's Avatar
I run a stock 26" tire on my motor and when I go to spray I use 28" rear tires. I alos have 3.89's in the rear.
Old Nov 8, 2007 | 03:33 PM
GTslOw's Avatar
Thanks
Dave
3.42 here i run a mt et street 275/40/17 i spray a 175dp kit no traction issues in first
Old Nov 8, 2007 | 05:31 PM
purdueranger's Avatar
28x10.50s here but I also have 4.30 gears.
Old Nov 8, 2007 | 05:40 PM
DopeFedZ's Avatar
I'm running a 275/50/15 M/T drag radial on my h/c/n20 car. The one time I went to the track my 60ft was a 1.50 and that was spraying after launching the car on motor.
Old Nov 8, 2007 | 06:40 PM
ssfast99's Avatar
27 mt streets in first with 4:56 gears and no problem with my traction and nitrous h/c car
Old Nov 8, 2007 | 10:55 PM
DuronClocker's Avatar
I'm running 3.89s and a 26x11.50-16 ET Street, shifting at 6600.
N/A I'm trapping about 120. On the bottle, I'll find out this weekend. Should be somewhere in the mid 130's, which will put me right around 6600-6800 in 4th (PERFECT!)
Next year I plan on stepping up to a 28" full slick.
Old Nov 8, 2007 | 11:44 PM
TwoFast4Lv's Avatar
27x11.5s were not enough to come out of the hole on a 200 shot for me
Just went to a MADMAN suspenion and 325x50 DRs
Old Nov 9, 2007 | 03:08 AM
jmill96Z's Avatar
I felt the 26's were just about right when I ran 1/4 mile on a 150 with 3.42's.
Old Nov 9, 2007 | 07:02 AM
newtoLS1s's Avatar
Default Ya'll Rock!
Thanks so much guys, I really appreciate all of the responses, im in the process of getting some 15x10s and MT-ET-Streets so we'll see what I come out with.
Old Nov 9, 2007 | 10:46 AM
1lejohn's Avatar
You should be ok. Don't try and run an 11.5" tire on anything under a 10 inch rim. I did and they bow out, don't wrinkle the side wall and are unstable on the big end. The 27 will drop your gear ratio, but that's ok on spray. I think I'm running a 27 right now. I have a .4 sec delay on the launch before the N2O hits. The car will usually dead hook. I run around 16-18 psi in them depending on the track. If the car is unstable on the big end add a pound or two.
