help with installation
hey guys i just received my zex wet nitrous kit and i'm thinking of installing it myself
what do you guys think, do it myself or pay someone?
does anybody have the same set up on their car that can send me some pics.
thanks
thanks
well i tought about it and decided to do the installation myself
just one question
i have a throttle body spacer and the plastic thing in between the throttle body and maf sensor is kind of crunched up
i read the manual and it said that it should be put before the TB and after the MAF sensor
in my case would you recommend me to take off the spacer and run the nozzle on the plastic thing, or what would happen if i were to put the nozzle on the lid before the maf sensor
thanks for the help
if anybody has pics of their set up i'd really appreciate it
just one question
thanks for the help
hey guys im almost dome installing my wet nitrous kit
just had a quick question
it says to run one of the wires from the management unit to the output voltage lead from the throttle position sensor?
i located the throtltle position srnsor but their is 3 wires a black one, grey, and blue
to which one does it go to?
i got everything installed but the fuel line
im having trouble finding a way to put it on
i've tried looking online for pics of the setup byt cant seem to fnd anything
does anybody have a pic of how they ran the fuel to the unit
i noticed that their is like 2 fuel lines next to each other wich one is the correct one, what other set ups is their to run the fuel.
i looked at some threads and noticed the shrader valve was one way, would that be the best way, if so how is it done
thanks for all the help
on my zex kit it came with a 90 degree 4an female/male fitting that screwed onto the scharder valve.but u must remove the valve core first. if your kit didn't come with the fitting just find a shop that makes hydraulic hoses and they will have it.
Double check everything befor you try it !! Make sure the nitrous and fuel lines are going to the correct places ( zex box and jet ). Befor using the nitrous, make sure the wide open switch is working - listen for the solenoids to click.
