nitrous parts.....list needed!
Old Nov 27, 2007 | 11:50 AM
Havok2's Avatar
Default nitrous parts.....list needed!
i have a bottle and a purge
what else do i need to get a nice complete wet system? just the basics needed, no extras. no money...
nitrous solenoid
fuel solenoid
main feed line (how long usually? 18-20 ft?)
2 smaller lines (how long, 12 inches?)
WOT switch?
im new to the nitrous scene...sorry for the ignorance.
Old Nov 27, 2007 | 12:19 PM
Mike@HSW's Avatar
nitrous solenoid
fuel solenoid
WOT switch?
here are some essentials you may need
http://www.harrisspeedworks.com/shop...cat=364&page=1
the only thing it doesnt include would be the main line and a WOT switch which we can get you those for good prices. 18 feet would be enough for the mainline. gives a call if you get a chance and we can set you up with exactly what you need at a good price. if your not interested you can use the link to determine what you need to get a complete kit. Goodluck
Old Nov 27, 2007 | 12:25 PM
TARZAN's Avatar
nitrous solenoid
fuel solenoid
main feed line (how long usually? 18-20 ft?) This depends on where you want to mount the bottle/noids. 16' should get it though
2 smaller lines (how long, 12 inches?) Again, this depends on where you intend to mount your solenoids. You'd probably be better off with 2' lines, to give you a lil more room for adjustment. Depending on the noids, it should most likely be a -4 on one end (from the noid) and a -3 on the other (for the nozzle)
WOT switch? YES, plain and simple, put it on a WOT switch
Some other things you should consider....
Put your solenoids on a switched *on* (like a toggle switch) and a relay. Also, put an in-line fuse on your wires, safety measure incase anything were to ground out.
A pressure gauge is also a must, you NEED to know how much pressure you have in your bottle before you go out trying to spray. Depending on the bottle (some bottles have a place for the gague in the nozzle), you may have to get an inline adapter for a gauge, also.
The following are not *must haves*, but nice for added safety, if you have the $$$$...
Window switch, and a fuel pressure safety switch.
:edit:
Thanks for that link Mike, good POR, I knew I forgot something!!!.....Line from your fuel rail test port to the fuel noid
-Will
Old Nov 27, 2007 | 01:11 PM
Havok2's Avatar
thanks guys.
ill look at that site and pm you what questins i might have thanks!!
Old Nov 27, 2007 | 01:22 PM
2002t/a06's Avatar
why dont u just get a kit like this that doesnt come with a bottle?
http://www.dynotunenitrous.com/store...?idproduct=231
Old Nov 27, 2007 | 01:46 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
that would be the easiest way to make sure you have all the parts needed.
All of our kits are also availible with no bottle..
Old Nov 27, 2007 | 06:23 PM
2002t/a06's Avatar
there u go! either get a nitrous outlet or dynotune kit without the bottle!
Old Nov 27, 2007 | 06:30 PM
TARZAN's Avatar
I'm pretty sure any of our sponsors have prices on kits sans bottles
-Will
Old Nov 27, 2007 | 06:41 PM
Havok2's Avatar
true huh? lol didnt think of that
thank folks.
Old Nov 27, 2007 | 07:25 PM
Mike@HSW's Avatar
thank folks.
You cant go wrong with any of the nitrous vendors on this site. if your simply trying to figure out what you need just go to one of our websites and read everything that comes with our kits. If you have any other questions feel free to PM or give us a call.
Old Nov 27, 2007 | 08:20 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
-Will
exactly, the point I was making.
Old Nov 28, 2007 | 12:32 AM
TARZAN's Avatar
Oh, I know Ray, I was addressing the member who posted after you sir
-Will
