Hurt #6 with 175 shot why???
Old Dec 3, 2007 | 12:53 PM
SY732's Avatar
Default Hurt #6 with 175 shot why???
My friend burnt the #6 plug and lost compresstion in his LS2 why?
05 C6 LS2 built by lingenfelter base H/C with forged internals.
CAI
FAST
KOOKS 1 7/8
N.O. plate
N.O. stand alone
TR6's at .35
175 Jets (~160rwhp)
NOS progressive controller
100 octane in the main tank
112 Sunnoco in the stand alone
He sprayed the car with low bottle pressure started at 900 it dropped to 700.
It broke up in the big end and burnt the #6 plug and lost compression
What do you guys think happened?
He thinks it was too rich, I am thinking it must have been lean???
Could the #6 injector be bad?
Old Dec 3, 2007 | 02:04 PM
TARZAN's Avatar
Did he datalog the pass? Does he know what his a/f was? Did it get a head gasket or a piston?
-Will
Old Dec 3, 2007 | 03:52 PM
SY732's Avatar
-Will
Datalog: no
AF: no but all other plugs look good including 5 and 7 which are suposed to be the leanest right?
head gasket or a piston: not sure yet
Old Dec 3, 2007 | 05:57 PM
GasTiresandOil's Avatar
#6 injector failed?
Old Dec 3, 2007 | 06:01 PM
Bullitt4110's Avatar
Ive seen the LS2 injectors fail before. And it ruined the motor.
Old Dec 4, 2007 | 12:21 AM
daniel6718's Avatar
yeah an injector must have done that...whats weird exspecially to hurt forged internals....
low bottle pressure like that too...sounds like it was very safe just lost fuel on that cylinder
Old Dec 4, 2007 | 08:07 AM
Gimp98TNT's Avatar
I've also seen an injector fail and take a cyl. out before.
How much timing was he running??? Just because it's forged doesn't mean its indestructible.
Old Dec 4, 2007 | 08:39 AM
Zero4488's Avatar
Restricted User
wow...that sucks...just goes to show you...you can build a motor and even something stupid can screw it up...
Old Mar 14, 2008 | 11:52 PM
SY732's Avatar
Ended up just hurting / burning a valve, still would like to know why
Old Mar 15, 2008 | 09:32 AM
ls2 bait's Avatar
that tr6 plug is too hot also.
Old Mar 15, 2008 | 09:36 AM
ssfast99's Avatar
just curious, why is a tr6 to hot for a 175 shot. i am going to be trying a 200 wet shot and want to make sure i choose the right plug.
Old Mar 15, 2008 | 10:10 AM
TWS's Avatar
TWS
Heck, I run a NGK 5553 just on motor in my LT4. When I spray I go to a 6097 (BKR7E). I wouldn't mess around with a TR6. It can't pull enough heat out of the cylinder to avoid detonation. Of course it also depends on how much timing he is running. Can't say if my choices would be perfect for his set up. I'd say call NGK or look on their website - they have a lot of tech details right on the site.
Old Mar 15, 2008 | 11:52 AM
ATVracr's Avatar
It was rich. To rich will hurt the motor just as fast as being lean.
Most people will say "leave it a little rich to be safe" NOT TRUE on N20. The only safe tune is the right tune.
Old Mar 15, 2008 | 05:52 PM
ls2 bait's Avatar
i run a tr8 in my car. i ran a tr6 when i ran it on motor. im not expert i just think thats too hot for the amount of pressure/ heat u r building in that cylinder.
Old Mar 16, 2008 | 04:42 PM
Robert56's Avatar
The tr6 is an extended tip plug, even though it's colder than stock plug if anything at all goes wrong you end up with a glow plug that could spell destruction. All the real experts will tell not to run an extended tip plug with the hose. Yes, I kow many do, but a smaller hit is more forgiving, and even then it's doesn't mean it's the best plug. Starting with the tr7 the tips are no longer projected.
Robert
Old Mar 16, 2008 | 05:55 PM
cdubbzz's Avatar
+1, too much fuel can cause major issues
