Nitours fuel system
Old Dec 8, 2007 | 04:01 AM
Bandit28's Avatar
Default Nitours fuel system
When running a seperate nitrous fuel system on a fbody, would I want to run a low pressure pump or high pressure pump?
Old Dec 8, 2007 | 08:32 AM
DopeFedZ's Avatar
Low pressure.
Old Dec 8, 2007 | 02:37 PM
Bandit28's Avatar
Thank You
Old Dec 8, 2007 | 04:35 PM
wyndzer's Avatar
Why would you run a low pressure system? I would run a high pressure stand alone since the car runs a high pressure system. If it were a carb setup then that changed everything.
Old Dec 8, 2007 | 06:16 PM
Speed Density's Avatar
hashtagBMW
Low pressure stuff is easier to tune.
If you have the ability to choose, then go Low. You can run a standalone as well.
I went with High pressure becuase im running everything off a magnafuel pump.
Old Dec 9, 2007 | 03:12 PM
TARZAN's Avatar
What style nitrous kit do you intend on running?
-Will
Old Dec 9, 2007 | 03:51 PM
MeentSS02's Avatar
Kleeborp the Moderator™
You'll get more jetting options for smaller wet shots if you use a LP system...if you run a high pressure stand alone, and want to run a fairly small wet shot, you'll need to run a tiny fuel jet, which could get clogged way more easily.
The difference between the two should only be a spring change away in the regulator on the stand alone...if it were me, I'd run a LP stand alone setup to allow more flexibility with the fine tuning.
Old Dec 9, 2007 | 04:27 PM
Bandit28's Avatar
-Will
anywhere from 200-300 fogger homemade redneck kit
Old Dec 10, 2007 | 11:11 AM
TARZAN's Avatar
just wanted to make sure we were talking direct port....if so, either/or lol
-Will
Old Dec 11, 2007 | 11:06 AM
Bandit28's Avatar
yes TARZAN direct port nitrous system
