What controller to get?
Old Dec 11, 2007 | 11:22 PM
pHEnomIC's Avatar
Default What controller to get?
I really like the functionality of dynotune's a/f lean shutoff. It seems to have WOT + a/f shutoff. It seems that this wouldn't require a FPSS. I would like to however get an rpm based or progressive controller. Should I get two and use them together? Is there any other brand that has all those features?
I already have a wideband to take advantage of the a/f controller.
Old Dec 11, 2007 | 11:51 PM
firefighting1101's Avatar
im running a timing tuner and the dynotune a/f shutoff
Old Dec 12, 2007 | 12:26 AM
Hennytime's Avatar
ill be running a dynotune switch, wot switch and a window switch.
Old Dec 12, 2007 | 01:23 AM
myfast70's Avatar
You can use a Progressive with the dynotune lean switch. They even have a wiring diagram for it in their instructions. FJO seems to be one of the best progressives out there but you nned a computer to program it.
Old Dec 12, 2007 | 02:14 AM
pHEnomIC's Avatar
What is the cheapest progressive or best bang for buck controller on the market? I think id like to get the dynotune a/f on and piggy back it with a progressive one. The FJO seems nice but a little pricey.
Basically the function i want overall: I want to be able to hit a switch, stage, and launch and i want the nitrous to come on automatically at a set rpm without busting my tires loose all over the place, and then shut off between shifting.
On top of that: want the nitrous to shut off if it gets too lean or something.
Old Dec 12, 2007 | 06:09 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
Here you go, everything you want in a small package, you mentioned progressive, plus a lean cut, how about a window switch, shift, large list with this thing.
Old Dec 12, 2007 | 07:11 AM
70Stang's Avatar
Saw that new NX gauge/controller at PRI...guys, you have NO idea how nice that thing is...you have to see it to believe it!
Old Dec 12, 2007 | 08:28 AM
pHEnomIC's Avatar
I really like the functionality of the trick performance gauge, where can i buy one of those?
Old Dec 12, 2007 | 09:08 AM
NXRICKY's Avatar
Nitrous Outlet, NX, Dynotune all have them. Won an award for best new product at sema.
Old Dec 12, 2007 | 09:44 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
Give us a call....we have them in stock
Old Dec 12, 2007 | 10:39 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
which wideband do you have?
