Am i missing something..
Old Jan 9, 2008 | 01:00 AM
chetmo's Avatar
Default Am i missing something..
Ok guys im getting ready to purchase my setup soon..i have read read read and read... First let me explain the events going on with my car. Its a v6 at the moment... LS1 tranny with all accesories will be here next week...so why not have fun on the sixxer before it gets pulled? ( i will purchase a plate kit when the Ls1 goes in)... I have recently bought Hp tuners and adapting to the tuning. once again i have done a ton of research..but as i piece everything together to purchase in the morning i fell i am forgetting something!
HSW Sudden Impact Single Nozzle Wet Nitrous Kit (LSX) byunspeed=350
NX blow down tube..20 bucks(byunspeed)
Bottle warmer (opinions..suggestions?)..dynotune=99
FPSS...dynotune=40
window switch..still searching for a good one (opinions..suggestions) byunspeed=100
p.s. i will add a dual purge kit very soon also! (dynotune 70)
Old Jan 9, 2008 | 07:19 AM
TXZ0603's Avatar
how much do you plan on spraying? That could have a small impact on what other parts you might buy.
AF switch
guages
switch panel
remote bottle openers?????
Are you spraying big? Will you be needing a progressive controller?
And the list go's on..............
Old Jan 9, 2008 | 07:23 AM
Rick@HSW's Avatar
a few suggestions for you...
bottle heater: http://www.harrisspeedworks.com/shop...age=1&featured
window switch: http://www.harrisspeedworks.com/shop...9&cat=0&page=1
other than that...looks like your good to go. let me know if ya have anymore questions.
Rick
Old Jan 9, 2008 | 10:42 AM
chetmo's Avatar
AF switch
guages
switch panel
AF switch i will probably get when the LS motor goes in
Guages..same as above
switch panel, i will be building my own
remote bottle opener..the bottle will be right behind me
and i dont plan on going over 100...MAYBE 150 at the most...ever!
Old Jan 9, 2008 | 10:45 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
FPSS...dynotune=40
This is all that I see missing from a good base kit.
You will need the fitting to attach the blow down tube to the bottle.
These normally run $20-25
One step colder plugs NGK TR-6 or equivalent $15.92
Nitrous pressure gauge ~$20
But overall looks like you have the basics covered.
On the bottle heater there are many different options out there, they will all work about the same. Some claim they work faster than others but 20% of 15 minutes is only 90 seconds faster. I would find one that is easy to remove from the bottle and looks good when installed. I really like the 860 Performance heater as it integrates the bottle and bottle bracket into one unit. It also comes with wing nuts for the main feed line and the bottle brackets. This makes it very easy to remove the bottle.
http://www.nitrousoutlet.com/catalog...product_id=693
I also prefer heaters that use a pressure switch rather than a thermostat to regulate bottle pressure.
For a window switch, I would recommend a digital unit over one of the pill operated boxes. This will make it easy to change settings without having to carry a box full of RPM pills with you. We have both single and dual channel digital window switches. Features will vary slightly between the units, some a RPM switches only and others will integrate TPS activation and others will have a gear lock out feature that can help with wheel spin in lower gears.
Please let me know if you have any questions concerning any off these items.
Ray
Old Jan 9, 2008 | 10:52 AM
chetmo's Avatar
Ray
was unaware of the bdt fitting, i have the tr6's in my cart, and that is a nice warmer but a little too much,i can always upgrade though. And i think the MSD window switch should be what i need.
Old Jan 9, 2008 | 11:08 AM
Nitro Dave's Nitrous Outlet's Avatar
We are also now offering a single Channel windowswitch with built in TPS activation for only 99.00. So if Price is a reason for choosing a basic windowswitch check it out. The TPS activation is well worth it.
Dave
Old Jan 9, 2008 | 06:02 PM
DynotuneN2O's Avatar
LS1TECH Sponsor
I would go with this window switch, yes it is $129 but you get single stage or dual stage window control, Built in electronic tps and multi gear lockout. Works extremely well.
http://www.dynotunenitrous.com/store...?idproduct=194
If you do not need all the features it looks like Nitro Daves new switch is also a good option either one I would choose over the MSD.
For a heater I would recommend our 300 watt heater - the best performing heater on the market priced at $99.
http://www.dynotunenitrous.com/store...p?idproduct=17
Enjoy!
Dean
Old Jan 10, 2008 | 01:00 AM
chetmo's Avatar
WOAH! i will call tomm. and pray i can swap out my order from the MSD window switch, also guys i will be basically be buying a few dynotune accesories, N20 outlet, and HSW. Just preference and all of you get my money ...just not all of it..
Old Jan 13, 2008 | 11:38 PM
Anytime. Thank you for your support.
Dave
