#1 A/F safety product back in stock!!!!!
LS1TECH Sponsor
i am wondering without a wideband how well does this work, i mean when you install an a/f guage and run it off a tapped o2 sensor wire it reads all over the place...so does the reading when you use just an interceptor gauge using the computer port.
LS1TECH Sponsor
Dean
http://www.neweraperformanceparts.com/default.asp?S=503&A=E&PKV=202|0
this is the interceptor gauge. it reads a lot of stuff including 02 voltage off the computer. its usually all over the place, but thats why i have the wideband.
LS1TECH Sponsor
http://www.plxdevices.com/products/dm200obd/
But yes the narrow band signal scales up and down continuously but will go steady at WOT.
Thanks!
Dean
so will I be able to use this as my A/F meter instead of buying a wideband? I mean the car will only be sprayed once in a while but on the motor I should be find regarding A/F if the tune is spot on right?
2002t/a06 - THanks for the post. Interesting gauge - now that you sent the link I have seen it. Similar to the PLX we will be carrying when they are out.
Thanks!
Dean
Thanks!
Dean
i have ur wideband and will be hooking the shuttoff switch up to it whenever i have the time. im gonna put all my faith in it! no fpss. Thread Starter
LS1TECH Sponsor
Dean
This guage/display can take the place of my LC-1's square display guage?
I'm assuming it's got a circuit interrupter for shutting down the nitrous? Meaning I could just wire it inline with the ground wire on the control side of my N20 relay and it would kill the ground (and therefore N20) upon lean condition at WOT?
LS1TECH Sponsor
Youc an put it anywhere you like - mount it where you want - if you dont want it visible at all times you can also mount it in the glove box or center console.
Dean
LS1TECH Sponsor
Yes it has a circuit for shutting down the nitrous - here is how it is wired up:
http://www.dynotunenitrous.com/store...N%20SWITCH.pdf
Dean
So does this take the place of a FPSS? I will be running the "Timing Tuner" to remove timing for N2O use and as a Window switch. Also a N2O filter with my HSW wet plate kit. Will this work for me? Does this tell me the A/F ratio all the time off of my stock O2 sensors? If so I will order right away.....Thanks....Sorry about the "newbie" questions. I am trying to set up a safe system.....
