MSD Window Switch question
Old Jan 10, 2008 | 12:23 AM
Z28Caves60's Avatar
Default MSD Window Switch question
Me and my buddy are currently hooking up my new nitrous kit. We are wondering how to hook up the tach wire (white wire) into the car? Any good ideas...thanks
Old Jan 10, 2008 | 12:48 AM
95 Z28's Avatar
I did mine by splicing into the tach out put wire right off the computer under the hood. It's a different wire on my 98 than it is on your 99 so either do a search for "tach signal wire" or something like that, or I'm sure someone with a 99+ car will just chime in and tell you which one it is.
Old Jan 10, 2008 | 12:59 AM
chetmo's Avatar
if i was at work i could pull up every wire and pin number etc for you! but yeah just search for it!
Old Jan 10, 2008 | 01:01 AM
95 Z28's Avatar
I'm a nice guy, and I'm really bored so I did the searching for ya... Looks like you're going to splice into Pin 10, it's a white wire, on the red connector
Old Jan 10, 2008 | 09:30 AM
chetmo's Avatar
i will check this out at work also... 2 confirmations is better than one..and i might be bored LOL
Old Jan 10, 2008 | 09:47 AM
Z28Caves60's Avatar
Alright thanks man ill let you know im finishing up the kit today...
Old Jan 10, 2008 | 10:08 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
this is also tach signal..
https://ls1tech.com/forums/nitrous-oxide/501965-nitrous-related-wiring.html
post #37
Old Jan 10, 2008 | 10:51 AM
Z28Caves60's Avatar
ah yes that made it real easy...Thanks A lot
