Think i made a mistake goin wet.
I thought that I would get a fuel pump and keep the stock injectors and spray a 150 wet. I am beginning to realize that injectors are a must as well so I plan on buying them.
Did I screw up by buying a wet kit?
I feel the disadvantages I have are : Slightly higher chance of detonation and I have to pull timing from my n/a driving
What advantages do i have?
There are lots of nitrous accessories out there to pull timing only when the nitrous is armed also...thats what i do
but maybe Robert will convince me to go dry
I plan on installing a racetronix kit with harness for sure.
Dave
So i think it is gonna be:
150 wet (have) (hsw kit)
torquer v3 w/ supporting mods (n/a)
trick performance p series gauge w/ all safety stuff including wideband a/f shutoff
tr-6's
racetronix kit
purge kit
some type of ignition retard box
tuning
blowdown tube
bottle heater
purge
blow down tube
Any further suggestions or criticizing?
Dry: New Tech (EFI, advanced VE)
That's why most still like wet, it's what they know, but Dry is making some gains to be sure, lol. good input given on your injectors, however, if your at 95% DC, it really say's ya need injectors even running a wet hit, though it's not the wet causing the need.
Robert
I haven't seen any criticizing....
So, here are some questions I have.
Did you actually buy a new pump, or just the hotwire kit?
How long did the inj. duty cycle hit and stay at 95% (it just seems odd that you have max'd out the inj's with your mods. It could have been a momentary glitch, etc)
tr-6's
racetronix kit
purge kit
tuning
blowdown tube
bottle heater
purge
blow down tube
I have serious doubts that a properly operating LS based EFI system has outgrown it's stock injectors with only 400RWHP. If your IDC is at 95% I suspect something else is awry.
N2O wet...
No additional fuel required through injectors on wet N2O set-up. So, even if your injectors are at 95%, you have room, not much, but your fine. Others have said it already, use a BAP.
MOST IMPRTANT: INSTALL A WIDEBAND to watch AFR both NA and especially squirting a wet system, this will help you dial in the jetting on the fuel side of the wet N2O system.
I am at 97% duty cycle with the stockers. With a wet 150 shot the injectors would need to be replaced for some peace of mind. also the fuel pump is probabaly a culprit if you are on the stocker.
