gaping plugs for a 250 to 300 shot
Personally, I put a set of #6 plugs in my car, use them to load the car on/off the trailer and warm it @ the track, go thru tech, all that. Then before I run it I swap a set of #9's in and make a run, and check at least a couple on the return road. If all looks o.k. I put them back in, go back to the pits and check every plug, if they look o.k. I will run them again, if anything doesn't look 100% I change all 8 and make whatever adjustment I have to. (bottle pressure, whatever)
When starting off with Nitrous, this is a must IMO if you want to learn the tuneup and make sure everythins is safe. Plus you can work your way up on the tune this way too, if it's a little lean with a cold plug the liklyhood of hurting something is alot less then if you start off with one that's too hot.
Keep in mind, I'm running a 13.5 to 1 compression 402 and am only on a 150 shot, and am using Torco 118Nos blend fuel, and a #9 heat range plug. Not that I have to, it's just safer. I probbaly could run 116 fuel and a #8 plug, but I'd just rather be safe.
Start with a #7 if it's a stock compression motor.
Plugs are a cheap tuning tool, and are easy to change, if you foul them out, you'll know, it will start hard when the car is cold, and will idle crappy. Better to start a little too cold and foul a set of plugs, then start too hot and melt a piston.
