Mounting bottle on trans tunnel
Also, as far as blowdown tubes go, what should I do in order to get a blowdown without cutting a huge hole in the carpet.
BTW, HSW 10lb bottle.
Bill
http://www.860performance.com/catalo...18&product=523
As far as the blow down tube, I would think you would need a long braided line first. You could pull the carpet up underneath one of the back seat cushions just a little, punch a hole through, run the line, replace the carpet, and put the seat cushion back in.
it does look odd, and I agree that it looks odd in the pic.
but the brackets are dyno tune brackets, and for the base my brother and I made the mount.
That pic does kind of look like its wrong.
oh and in that pic it is down some, that pic I took when I had first finished it.
I have since put different bolts and some lifters for the front...
the bulk head went in on the side, and I did not move it forward enough for the seat to go back in...
Driver side rear, yes can be sat in no problem.
actually I slept in it, passed out across the bottle... thank god the wife did not take pics of that...
I had the wifes friend sitting back there when I was hitting it..
she was using the bottle as an arm rest.. LOL
