tach wire problems
Old Feb 14, 2008 | 12:04 AM
killerv6's Avatar
Default tach wire problems
ok so i have had a couple of nice guys send me a link on were to find the tach wire on the pcm, well from 99-02 camaro the bottom pcm with #10 pin should be a white wire well i went to hook up my window switch today and went to tap into the pcm but when i looked at the #10 pin it was not white it is purple so im confused now on what to do could some one help me out thanks.
here's the link.http://www.installuniversity.com/ins...ht_install.htm
Old Feb 14, 2008 | 12:11 PM
killerv6's Avatar
anyone? i sure would appreciate it.
Old Feb 14, 2008 | 12:35 PM
Z28Caves60's Avatar
Recheck to make sure you are tapping into the right connector. Red connector, #10 pin white wire. If that is still the case i suggest trying to findout why its not the rigth wire. i.e. motor swap to a different year LS1
Old Feb 14, 2008 | 12:47 PM
Z28Caves60's Avatar
Wait i noticed you name, are you trying to tap into the tach wire on a v6 camaro???
Old Feb 14, 2008 | 01:03 PM
killerv6's Avatar
yes im trying to tap into a v6 camaro. you said the red connector mine is clear and the top one is blue think they put a different connector in there thats why?thanks
Old Feb 14, 2008 | 01:52 PM
killerv6's Avatar
ok i called gm up and told them that im trying to hook up a window switch and im needing to find the tach wire on the pcm, i told them that a couple of guys said its the #10 pin on the bottom pcm and it should be a white wire. he said that it should be a purple wire and its the oxygen sensor i told him thats what color mine is. they said the only one it might be is the #8 white wire and its called the engine speed signal anyone got any ideas. i would appreciate it.
Old Feb 14, 2008 | 07:16 PM
Z28Caves60's Avatar
That would most likely be it. See everyone was telling you the wiring for a 99-02 LS1 camaro. See i dont know anything about the v6 cars but it sounds right what the gm tech told you. Hope it helps
Old Feb 14, 2008 | 08:03 PM
ScramingYellowZonker's Avatar
this is the only thing I could find for the V6
Old Feb 14, 2008 | 09:03 PM
killerv6's Avatar
can i ask were you got that diagram at thanks.
Old Feb 14, 2008 | 09:14 PM
Mitchel on demand
Old Feb 14, 2008 | 09:26 PM
usd2sing's Avatar
white wire, proven.
why would u call the dealer and ask them??
like they'd really guide u in the right direction in hooking up a nitrous system.
search the boards for 00-02 shift light install, same same process.
Old Feb 14, 2008 | 09:45 PM
Originally Posted by usd2sing
white wire, proven.
You do realize this is for a 6 cyl not an LS1...
Old Feb 14, 2008 | 09:51 PM
the white shows for ignition control????
Old Feb 14, 2008 | 09:54 PM
usd2sing's Avatar
Talking
heheeeheheee.....yeah...kinda...i own 3 of them.
all 3 99+, all with window swtches installed.
the brwn wire is my ws lead on the 02 camaro....yep, v6...lol
Old Feb 14, 2008 | 10:06 PM
Sorry didn't know... I don't know anything about the 6 cyl. +1 for you.
Old Feb 14, 2008 | 11:32 PM
killerv6's Avatar
ok thanks scraming. i did hook mine up to the #54 pin i was reading were floyd hooked his up to it thanks for all the help.
