Is this a MUST to do?
Old Feb 22, 2008 | 12:43 AM
bmxer8699's Avatar
Default Is this a MUST to do?
Is it absolutly needed to change out the stock fuel pump to run a dry 100shot on an ls1 99T/A with a full exhaust.
I hear this story going both ways.. I wouldnt normally object to upgrading, but my stock fuel pump was replaced a year ago, and it was a pain in the *** to do.
Thanks
-Rams
Old Feb 22, 2008 | 12:47 AM
Beer99C5's Avatar
99's have the 26 pound injectors, be sure to watch your AFR, anything above a 50 shot went lean for me (however, others have no problem), I had to up the injectors to (went 42's) get it to be safe.
Old Feb 22, 2008 | 07:59 PM
BOLO's Avatar
When the NX kit went in so did a Walbro 255lph intank fuel pump. Always one step ahead.
Old Feb 22, 2008 | 08:17 PM
landonew's Avatar
Dude it's cheap insurence. But not ABSOLUTELY necessary. Just remember that fuel pumps are like all other parts. Older ones don't pump as much fuel as new ones, so if the pump has a lot of miles on it that it is probably a good idea to assist it. Just my .02
Old Feb 22, 2008 | 08:19 PM
sprayed_z's Avatar
Go wet if you want to be safer
Old Feb 23, 2008 | 12:50 PM
bmxer8699's Avatar
hmm, well the pump might have 10k miles on it.
Old Feb 23, 2008 | 01:16 PM
bjamick's Avatar
You will be just fine .
Old Feb 23, 2008 | 03:04 PM
myfast70's Avatar
It's worth spending a couple extra $$'s & time now than a whole bunch later when **** blows. Just use the trap door method for swapping the pump and you should have the whole thing done from start to finish in less than an hour.
Old Feb 23, 2008 | 05:23 PM
BOLO's Avatar
That is one awesome access to the pump! I like it.
Old Feb 23, 2008 | 05:41 PM
LT1PwrdZ's Avatar
I have an inline boost pump on my dry 125 shot and i have no problems.
Old Feb 23, 2008 | 07:07 PM
myfast70's Avatar
Thanks!
Old Feb 23, 2008 | 07:21 PM
JimmySprinkle's Avatar
Eh, I'd recomend upgrading the intank pump, or at least buying an inline pump. I just juiced up my v6 'bird with a 100 wet shot, but a guy I was talking to gave me an interesting analogy. Think of going skydiving, and you can either use a single parachute (cheap) or 'chute with a backup (say, $255 like a Walbro fuel pump).
Sure, most people never HAVE to use their backup 'chute, but you'll feel a hell of a lot safer with one IMO.
Old Mar 10, 2008 | 12:46 PM
bmxer8699's Avatar
never thought of it from a sky diving perspective. i think ill go ahead and get the fuel pump when i get my tax return check
Old Mar 10, 2008 | 01:16 PM
TNTramair's Avatar
my condom analogy allways works....you dont really need one but think of what can happen if ya dont have it...
