Dry DP questions......to ponder....
Dynojet Fan
Say I wanted to do it.... I already have the pnp racetronix harness & fuel pump.. All I would need is the injectors, BAP, nozzlels, noids ect...
So the question is what injectors do/would i need to support say 1k rwhp?? 1k just to be safe.. If the inj. are low impd. I would need a driver box like the AEM along w/ the racetronix harness... I have efilive so I could do the cos5 option.. What do you guys think??
Do you think my 01 fuel system is up to the task?? w/ a bap & racetronix setup.
thanks...
thanks...
thanks...
thanks...
Robert
Dynojet Fan
That interface looks cool but im gonna go SD tune so the interface would not work... since I wont be useing a MAF
Ok so I have a question for you... Just something to ponder...
Most people go to a directport for the ability to tune each individual cylinder.
With a dry directport this is achievable as long as you have tunning software that will let you adjust each injector individualy. If you do not have software that lets you do so. You are missing the main bennifit of having a directport system.
Dave
Dave
Dave
Dave
Robert
Couldn't you just jet more nitrous into cylinders that run rich, and less into cylinders that run lean? I don't know if you'd be able to make small enough changes by going up/down a jet size, but in theory I don't see why not.
Your fuel system probably isn't up to the task, if you have to ask.....
I also hope you have a pretty well built engine if you want it to last.
Robert
Robert,
Different applications have different flow charastics. Take for instance a set up that has a custom ported intake and heads. One cylinder may be burning hotter do to the flow in that runner. I have seen applications that needed quite a bit of a different fuel jet in that cylinder for tunning. How do you do this if you can not increase the fuel to that specific runner?
Dave
Dave
Dave
Doesn't nitrous increase horsepower by allowing you to burn more fuel? So if you're decreasing or increasing the amount of fuel you inject then aren't you changing the HP output? I'd rather have a slightly less even distribution of nitrous if that resulted in more even EGTs across all cylinders. But tuning by changing nitrous jets is just a bandaid. I think BS3 plus a direct port dry is the ultimate way to go.
Robert,
Dave
Dave
Here's the deal, 90% of the guys on the boards are not NHRA players (limited class rules where every hp counts) and the couple ponies difference from having exact EGTs or a/f per cylinder are not going to matter. It's normal for the cylinder temps to be off. From what I have seen and heard, is the Dry DP has more consistent a/f/ and temperature per cylinder than do the wet direct ports. So, what you say has an affect on running DP Wet hits also, but you have never brought that up in the wet threads, lol.
Does any one running n/a, tune per cylinder, no. That's the same as the dry hit using the n/a injectors and look up tables, so who is going to additional per cylinder tuning? You'll end up with the dry hit having the same variances as the n/a cylinders. The reason the wet hits vary so much per cylinder is the way they get the extra fuel, and thus end up with worse per cylinder temp and a/f than a stock or dry hit motor. In conclusion, the DRY hit generally needs no additional tuning per cylinder, unless you wish to, and the wet hit needs tuning per cylinder to get it back at least to stock variances.
Anyone on this board doing per cylinder tuning? If so, what's the method 8 EGTs, 8 WBs, or reading each plug?
Robert
I may even disagree with Al on the need to go DP when wanting a big hit concerning dry. I think the DP Dry is viable at any HP level, and no need for any more tuning than for going down the neck. Both methods will be fine. Can we say good bye wet hits, lol.
Robert
My point is that the Dry DP will need no tuning, though the Wet DP will.
Robert
Robert
