Braided blow down tube
Old Feb 28, 2008 | 08:42 PM
TFRO's Avatar
Default Braided blow down tube
Can somebody tell me where I can get one of those steel bradied blow off tubes? Thanks
Old Feb 28, 2008 | 09:02 PM
adam`'s Avatar
you just make it. the fitting is already a 8an? off the bottle.
Old Feb 28, 2008 | 10:18 PM
myfast70's Avatar
You can also have HSW make one for you as they do all sorts of custom hoses.
Old Feb 28, 2008 | 10:25 PM
quickblade's Avatar
go to a local store and get the hose.
Its steel braided hose is all it is.
Check the strength of it, and what is required.
But it is quick and cheap to run down to the local race store.
auto parts? not sure of there, race shop will have it.
where you get your nitrous filled up at.
Old Feb 29, 2008 | 12:03 AM
TheBlurLS1's Avatar
That's what she said...
You'll need 2 -8an hose ends, I used a straight and a 180. You'll also need a -8an bulkhead with nut, I used a 90* bulkhead.
Old Feb 29, 2008 | 12:05 AM
caliswangin916's Avatar
hydraulic sto. industrial and others that may carry parker brand thangs.
Old Feb 29, 2008 | 10:15 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
that is correct....we also sell a prepackaged kit. The kit comes with 3' of hose and all of the fitting needed.
http://www.nitrousoutlet.com/catalog...roduct_id=1116
Old Feb 29, 2008 | 05:11 PM
TFRO's Avatar
thanks alot for the help.
Old Feb 29, 2008 | 10:09 PM
myfast70's Avatar
Sweet setup! That would also look great with the black nylon braided line (and even have a few ounces of weight savings)
