Ms3 And N20 Step In
Old Mar 7, 2008 | 08:23 AM
Jpr5690's Avatar
Default Ms3 And N20 Step In
Using Prc 5.3l Stg 2.5 Heads And A Ms3 V3 Cam How Much Total Timeing Should I Be Suing For A 150 Shot, And For A 200 Shot
As Of Now Im Running About 29deg Of Timeing N/a And I Was Gonna Pull 6 Deg For The 150 Shot But Am Not Sure If This Is Good Enough..
Old Mar 7, 2008 | 11:03 AM
GregWS6&z28's Avatar
6-7 degrees. may have to go 1 or 2 more with a 200 shot
Old Mar 7, 2008 | 12:29 PM
ICRAZY6's Avatar
I usually do 2 degrees for every 50hp.
Old Mar 7, 2008 | 02:10 PM
Jpr5690's Avatar
Yea But What Was The Original #'s You Pulled From
See If Im Running 24 Deg Stock And Someone Is Running 29deg With A Large Cam Mabye That Rule Of Tubmb Dosent Hold Up
Old Mar 7, 2008 | 02:22 PM
Jpr5690's Avatar
Spoke With Tsp And For Shots Under 200 They Said 5 Deg Is Fine For My Setup
Old Mar 8, 2008 | 09:06 AM
did they say 5 degrees for stock timing, or 5 degrees from max timing (post cam, etc)
Old Mar 8, 2008 | 09:58 AM
black01_WS6's Avatar
That is very important as you don't want to blow up the motor
Old Mar 8, 2008 | 10:18 AM
FoolZRacing's Avatar
Im guessing he's meanin post cam. Jason pulled 3.5 degrees on the 150shot on mine and richened up the PE 3 % and it was a 11.2 a/f ratio the whole pull.
Old Mar 8, 2008 | 03:09 PM
Jpr5690's Avatar
yea they said 3-5 degrees and i told them i was ms3 cammed and 5.3l heads with their base tune
Jpr5690's Avatar
ill prolly start with 6 deg
Old Mar 10, 2008 | 10:32 AM
Jpr5690's Avatar
N E Other Replies?
Old Apr 8, 2008 | 09:06 PM
Jpr5690's Avatar
Is This Dead?
Old Apr 8, 2008 | 10:29 PM
jmill96Z's Avatar
I run 24 total with a very similar cam
Old Apr 9, 2008 | 07:58 AM
Jpr5690's Avatar
This Is What I Was Thinking
