How To Pull Timing?
Old Mar 9, 2008 | 12:04 AM
hashbrown1087's Avatar
Banned - another scott mckinney alias
Default How To Pull Timing?
Hey Guys. How is everyone retarding their timing with their PCMs? For example, I have a new vehicle and tuned with HPTuners, running a 200hp nitrous kit and want to retard timing upon the button. I do not want to run a tune with a constant timing retard, but want to retard timing upon the button. What does everyone suggest? How do you make this happen?
Old Mar 9, 2008 | 01:09 AM
Z-RATED94's Avatar
There's different ways, but I like the Mallory 685 ign. box. I'm sure others will tell you about their choices.
Old Mar 9, 2008 | 01:48 AM
RedTtop6spd's Avatar
Nitrous Outlet has a good solution. I believe Harris Speed Works does as well. Not expensive at all considering how easy of a solution they are.
Old Mar 9, 2008 | 12:13 PM
madclown's Avatar
Timing Tuner, It's inexpensive, easy to use, and it has the window switch and adjustable delay built in...........
Old Mar 9, 2008 | 12:35 PM
Robert56's Avatar
HSW has the answer for the wet and dry users: the "Interface". Now if you happen to be running a dry hit and have a tuner program, in my web is a how to pull timing write up and it's free. I do have the Interface, as well as HPT and a dry hit, so been there before.
Robert
Old Mar 9, 2008 | 05:09 PM
SANDDEMON08's Avatar
I'm still learning all this myself but i'm looking at the timming twister from MSD. Not sure how good it is but it looks like a good product.
http://www.msdignition.com/tc_8625.htm
Old Mar 10, 2008 | 03:24 AM
Hi. Well we are running a late model SUV ECM & TCM, with an LS7 engine. I do not beleive the plugs will work from the MSD unit you mentioned above...
Is there anyway to do it within HP Tuners or similar? Please advise.
Old Mar 10, 2008 | 07:37 AM
black01_WS6's Avatar
I will be using the Interface to pull my timing- and it only pulls it when the N20 is activated.
Old Mar 10, 2008 | 11:58 AM
Chris@NitroDaves
Guest
Posts: n/a
I would use either the Timing Tuner or the Timing Twister
I'm personally using the timing tuner and Love it
http://www.nitrousoutlet.com/catalog...el=141&dept=11
-Chris
Old Mar 24, 2008 | 11:19 PM
How much timing retard is necessary on a 200 or 250 hp shot in the LS7?
Old Mar 24, 2008 | 11:24 PM
2 FAST 4 U's Avatar
usually for every 50 hourse you will pull 2 degrees of timing. So if you have a 200 shot like i do, you will pull 8 degrees of timing. I have the timming tuner and it is great. The one from harris speed works is really nice as well.
