timing tunner issues?
Old Mar 13, 2008 | 07:33 PM
ws98ta's Avatar
Default timing tunner issues?
Maybe be its me(n02 noob), but I am having trouble setting my timing tunner.
I would like to spary from 3000-5900 rpms and pull 4 degrees of timing.
I have the tunner set w/ key off
rtd 4
1-off
2-off
3-off
4-on
base 8
wot 0
rpm 0
turn key on wait for soild green.
I set the tuner the way I was told to by Chris(just like above)
after I get soild green I reset it to (w/ key on)
Rtd 4
Base 0
WOT 0
RPM 3
Mode 1 off
Mode 2 off
Mode 3 off
Mode 4 on
I this right?
I tried to spary just fuel(bottle closed) to check and see if it working. I got very very quick bog(maybe 1/10 of a second) then nothing. Got home checked the lines/ smelled like fuel. rechecked all the wiring and it was correct.
I think it is only spraying to 3000.
any help would be great! If you have a TT please let me know how you have it set.
I cant call Chris because I am at work the same hours they are open so any online help would be great.
Old Mar 13, 2008 | 08:07 PM
texasheat's Avatar
Call Harris Speedworks with a pen and paper handy...those instructions that come with the unit are ******* brutal!
Old Mar 13, 2008 | 08:14 PM
ws98ta's Avatar
I found them kinda confusing.
I didn't want to come on here right away asking stupid questions, so I read them first.
I guess I will give them a call tomorrow.
Old Mar 14, 2008 | 09:14 AM
Chris@NitroDaves
Guest
Posts: n/a
Give me a shout here at work and i'll go over the instruction and setup with you.
-Chris
Old Mar 15, 2008 | 09:46 PM
1BADAIR's Avatar
if its an older unit the confermation flashes are not right.
Old Mar 16, 2008 | 07:36 AM
ws98ta's Avatar
It says 1.1 on the cover. Is there any other way to tell how old it is?
What would the flashes be on the older unit?
Old Mar 16, 2008 | 09:00 AM
1BADAIR's Avatar
mine says 1.1 too. I think everything on mine just flashes once. One of the sponsors here was fixing the issue with them. Mine doesn't flash like it supposed to but works just fine
Old Mar 16, 2008 | 06:41 PM
ws98ta's Avatar
Ok I will have to try it the way i set it up.
I tried to spray friday night but the wot switch was not adjusted corectly.
Hopefully some time this week it will be nice enough.
Old Mar 16, 2008 | 07:07 PM
1BADAIR's Avatar
there was a thread somewhere that talked about the setup issue but I can't find it. I think Full throttle speed were the ones discussing it
Old Apr 7, 2008 | 06:58 PM
ws98ta's Avatar
bump for a new question!
Old Apr 8, 2008 | 09:52 AM
ws98ta's Avatar
nobody
Old Apr 9, 2008 | 12:30 AM
madclown's Avatar
Mine was the same way. The lights did not stay on for the 10 sec. just approx 1 sec each them off. It works great.
Old Apr 9, 2008 | 12:35 AM
jessedale98's Avatar
Will adjusting the timing tuner effect the Dyno tune that I got?
Old Apr 9, 2008 | 04:48 PM
ws98ta's Avatar
can anyone tell me if I have it set correctly?
Im not worried about the lights.
thanks!
