LT-1 Plate conversion
Old Mar 20, 2008 | 01:25 PM
Formula96's Avatar
Default LT-1 Plate conversion
Hello all, i have been digging through the sponsers and can't seem to find what i am looking for. I am currently running an NX universal wet kit. I want to change it to a plate setup, the only thing i could find was kits. Any one know of any conversions?
Old Mar 20, 2008 | 02:07 PM
starbucks's Avatar
nitro dave has a converstion kit. it is no doudt one of the best plates around for a lt1 and im not just saying it cuz i have one.
Old Mar 20, 2008 | 02:22 PM
Formula96's Avatar
The only problem with his is from what i read i would have to upgrade the throttle body.
Old Mar 20, 2008 | 06:45 PM
camar0corey's Avatar
Hmmm last I saw he had a plate for stock and a plate for the 58mm TB. I thought??
I know when I ordered the kit I had to pick between stock and the larger TB.
Old Mar 20, 2008 | 07:03 PM
starbucks's Avatar
yeah he makes a 52mm and a 58mm. The 52mm can be ran with the stock tb and stock intake manafold. The 58mm you would have to open up the two ports on the intake. i am running a 58 mm plate with stock tb and but i had to opened up the intake a little.
Old Mar 20, 2008 | 08:53 PM
BOLO's Avatar
Yes, you will need to upgrade to a 52mm TB to use his plate kit.
I'm running the 52mm plate myself.
Old Mar 20, 2008 | 09:19 PM
Formula96's Avatar
that sucks, anyone else have one, trying to be pretty cheap on that part seeing as how i will be doing safty upgrades to my system...
Old Mar 21, 2008 | 09:31 AM
Chris@NitroDaves
Guest
Posts: n/a
52mm Plate Conversion
http://www.nitrousoutlet.com/catalog...roduct_id=2807
To run this plate you wont have to modify anything.
58mm Plate Conversion
http://www.nitrousoutlet.com/catalog...roduct_id=2808
To run this plate all you will need to do is open the intake holes from 52mm to 58mm and you can still run the stock TB ( If you wanted to ) without a problem.
Mono Blade Conversion
http://www.nitrousoutlet.com/catalog...roduct_id=2834
-Chris
Old Mar 21, 2008 | 05:06 PM
Formula96's Avatar
Thanks ^^^
Old Mar 22, 2008 | 01:18 PM
97lt1z28's Avatar
Is switching to a plate from a nozzle worth 300 dollars?
