ARC 120v Bottle heaters
Has anyone used one? Can be run on 3 different DC Voltages 12VDC (car Battery) 13.8VDC (car alternator) 16VDC (Race Battery) ALSO can be run on 120 Volt AC (generater or house current. It puts out 400 watts on 120v, that seems like a lot. I have a race batt so I can leave a normal heater on right now, just looking for other options to heat the bottle without the car running.
They are bad ***. Call them and tell them what you want. I think it was like 105 for the kit with springs and all. We use them on all our bottles as a 120v and hook it right up to the generator. Those mother fers heat a bottle in no time. It will burn you. We try and keep as much load off the battery and starting system as possible. We have a bad *** Honda generator though.
Thats what I wanted to hear. I have a 13,500 watt generator so power isn't a problem, plus I always trailer my car so I always have power. I have never heard of them until last week. My friend is wiring up a racecar and the owner brought him the heater kit. When I looked at it I was really inpressed, it is a 100% complete kit, even comes with a roll of wire.
Same - just a better price and your supporting your favorite LS1 Tech suppliers!
http://www.dynotunenitrous.com/store...?idproduct=285
Dean
Dean
Dean
Dean
Dean
Dean
like this one for .99c
http://www.opamp-electronics.com/cat...ac-p-1242.html
Just be careful wiring the 120 correctly.
http://www.dynotunenitrous.com/store...?idproduct=286
Dean
Wattage is the same. Theres with the pressure switch and everything is not $140??? Its $220 plus. They use are same pressure switch in their kit. The equivelent version of there $140 is our $139
Dean
Dean
Thanks again for all your help.
Thanks for the link, even better. I will be ordering shortly. Do you have anything to control the pressure while on the 120? They have some kind of 120v electric regulator thats about $90 I think. I would like to be able to use the 120v and not have to worry about getting the bottle psi to high.
This kit includes the pressure switch, fittings, wiring, switch etc...
Are you looking for something different?
Dean
Dean
Dean
Yes, I dont ever plan on even using the 12v part. I just want something to control the 120v part. I already have nitrous in my car, I just want a 120v heater and a way to contol the bottle pressure so I dont have to watch the gauge with the heater plugged in. Arc hs what looks like a 120v temperature controller to control the bottle pressure. Do you have something that will control the 120v to maintain bottle pressure?
