Solenoids in Series
Old Mar 28, 2008 | 06:15 PM
JoeMama's GTO's Avatar
Default Solenoids in Series
Ok I searched and I came up with the fact that you are not supposed to wire solenoids in series; i.e. the "output" wire of one solenoid connected to the "input" wire of another solenoid and then to ground. What I didn't find is the reason why this is bad. It would seem that this arrangement would ensure that only both noids could open. I am switching over to a wet system and I want to make sure both noids open every time so if anyone knows any failsafes or tricks I am listening.
Old Mar 29, 2008 | 05:09 PM
Any ideas?
Old Mar 29, 2008 | 07:38 PM
NOS4EVER's Avatar
Connect both input together to the positive and both output wires to ground.
alaa
Old Mar 29, 2008 | 09:14 PM
Alt's Avatar
Alt
Yeah, either a splice, or wire nut, or shrink connector incoming power and the 2 input wires to make it look like a "Y" would be your best bet. Unless you really wanted to make a distribution block...
Old Mar 29, 2008 | 11:36 PM
SmaknaSS's Avatar
If you were to wire them in series, you would then be then dividing up the voltages that each solenoids see's. Say you had two equal identical solenoids, If you were to wire them up in series each solenoid would only see 6 Volts on a 12 Volt system. That would not be good.
Old Mar 30, 2008 | 07:30 PM
jrwireman1960's Avatar
Default solenoids in series
I would think that the two solenoids would just chatter if they did anything at all
Old Mar 30, 2008 | 07:42 PM
Randy WS6's Avatar
It will do what Smaknass said ,and is bad on the coils as well
Old Mar 31, 2008 | 05:21 AM
860 Performance's Avatar
What he said.
Old Mar 31, 2008 | 11:20 AM
Ok, so what if I used a transformer to boost the voltage? This just seems like it would be a good way to avoid the risk of one opening without the other...
Old Mar 31, 2008 | 11:30 AM
algws6's Avatar
for instance if the piston is swollen in the fuel noid it will still show voltage but not open. in this case it would not matter if you wired them in series. just test your noids every now and then, its preventive maintance and is part of the game.
Old Mar 31, 2008 | 05:17 PM
SmaknaSS's Avatar
You cant use a transformer to STEP UP the voltage with DC voltage's. Transformers only work with AC or pulsating DC voltages. Trust me, you dont want to go that route. even if you were to figure it out there would be more things that can go wrong than what it's worth. You would be defeating the original purpose. Just wire it the way the manufacture suggest.
