anywhere else?
Old Apr 13, 2008 | 08:00 PM
transamfreak01's Avatar
Default anywhere else?
ive used the search bar and didnt come up with anything.. i want to try something new. i dont want to mount the bottle in the spare tire well and dont really want to mount it on the hump. is there anywhere else a 10 or 15lb bottle can go? if you dont want to post it up you can pm me how you hooked yours up.
Old Apr 13, 2008 | 09:52 PM
97rs4life's Avatar
rear seat delete
Here is mine for my dual bottles and fire extinguisher.
Others have mounted it on the flat area under the back window which is above the axle and fuel tank. Or down in the ttop well area
Old Apr 14, 2008 | 01:29 AM
wow.. i like that but i dont really want to change the inside to much.
yeah i ask b/c i kind of want to put my battery in the spare tire spot but i dont really want to put the bottle on the hump. is there any room behind the back seats where the gas tank is? i was wondering if a little trap door could be made somehow if there was room.
Old Apr 14, 2008 | 05:22 PM
97rs4life's Avatar
gas tank is right up against the sheetmetal axle hump. What hump do you not want to put it on for sure? The hump between the back seats or the axle hump?
Old Apr 14, 2008 | 11:04 PM
Nitro Dave's Nitrous Outlet's Avatar
I have mounted them on the back deck before. However I suggest droping the fuel tank and bolting it through the bottom so you do not punch a hole in the tank. You want to make sure it is bolted down good incase you get into a wreck..
Dave
Old Apr 15, 2008 | 03:38 PM
well i dont really want to mount it on the hump between the seats but thats where its going if i cant find somewhere else.
Dave
i really like how it looks on the deck but cops out here are ridiculas. they will pull you over for any little thing so i dont really want the bottles smiling at him.
oh and by the way ill be ordering my money maker soon
Old Apr 15, 2008 | 10:17 PM
97rs4life's Avatar
do you have ttops? If not put it where the ttop holders usually are. Or mount it in the hole in the drivers side quarter panel where the cd changer usually goes
Old Apr 15, 2008 | 11:39 PM
You are running out of easy options. I have some other ideas but it takes some work and its info I would be giving you when I ship you your money maker intake back.
Dave
Old Apr 18, 2008 | 01:31 AM
so wait would the bottle stick out towards the passenger side then?
Dave
sounds good. going to pull the intake in a few days and then off to you it goes. what all do i need to send you?
Old Apr 18, 2008 | 08:50 PM
97rs4life's Avatar
yes it would face towards the pass side then towards the rear well
Old Apr 18, 2008 | 11:30 PM
yeah i dont really like that to much...
Old Apr 19, 2008 | 06:10 PM
robsquikz28's Avatar
just put it in the headlight and get a smaller bottle or gut the pass. seat *** board and place a small bottle there
