Wire Selection Chart
Old May 2, 2008 | 01:27 PM
Nitro Dave's Nitrous Outlet's Avatar
Default Wire Selection Chart
Hey guys this is a chart to help you choose the correct size wire when wiring up your nitrous system.
Dave
Old May 2, 2008 | 02:35 PM
daniel6718's Avatar
good info
Old May 7, 2008 | 09:35 AM
Thank you. I thought it may be useful to some...
By the way this chart uses a 2 percent drop..
Old May 7, 2008 | 09:39 AM
Chris@NitroDaves
Guest
Posts: n/a
Way to go Dave Excellent Thread
-Chris
Old Jul 2, 2008 | 10:34 PM
Back to the top for the do it your selfers
Old Jul 2, 2008 | 11:19 PM
myfast70's Avatar
Maybe this could be added to the sticky about wiring.
Good info
Old Jul 3, 2008 | 05:27 AM
Beer99C5's Avatar
When we make things idiot proof here on the rig, I usually remind the guys that "they" will just build a better idiot and mess up our new found process or information...
Here I am the better idiot...need some more info.
To effectivily use this chart the avg guy (like me) also needs to know how many amps each component draws: ie Heater +/-, relays for the Noids, switched side to the relays, Heater relay, opener +/-, purge w/o relay etc...
Old Jul 3, 2008 | 08:05 AM
Sigforty's Avatar
I was just going to ask the same stuff Jim. I would like to know what the Nitro Dave's noids use as a draw? I am sure for the other stuff like heater and opener you can get a decent base off of what fuse you are running in the wiring. Most Dynotune stuff I beleive likes a 25 amp fuse.
Old Jul 3, 2008 | 06:30 PM
SuperSlow02's Avatar
I just figured anything sending power or receiving power from the 12v should be at least 10ga anything sending a signal. at least 14ga. nothing burnt up yet lol. Good Info anyways right click save
Old Jul 3, 2008 | 11:56 PM
myfast70's Avatar
Most noids are between 25-30amps, heater 20+, switched of relay usually around 150mA (less than 1/5th of an amp), mechanical opener abour 2-3 amps. These are not the hard exact numbers for every component but will get you pretty close, purge is less that 5 if I remember correct.
