NANO Group Purchase
Guest
Posts: n/a
NANO Group Purchase
The Group Purchase you do not want to miss…
Nano Nitrous Systems
This group special is running through the end of MAY.
We need a total of atleast 5 orders to make this happen. If we get 10 orders or more we will have a deeper price. Your card will not be charged until we have enough to make the purchase happen. You can choose from any of the following systems
-------------------------Normal Price---5 or more---10 or more------------
Universal 10lb System______569.00______530.00_____500.00
Universal 15lb System______569.00______530.00_____500.00
Competition 10lb System____689.00______630.00_____600.00
Competition 15lb System____697.00______640.00_____610.00
You can call in your order at 1-866-648-7637
For those that are not familier with the NANO kits.....
GM High Tech Independant testing...
http://shopping.netsuite.com/core/me...e48ab&_xt=.pdf
The NANO Performance Advantage
NANO uses “mass flow technology” to constantly compensate for changes in bottle temperature and pressure. The results -
Constant maximum horsepower gain throughout the race.
Using NANO -180HP till nitrous bottle is empty
Without NANO – 180 HP for 1st 30 seconds only
Utilizes the entire content of the nitrous bottle.
40 seconds without NANO
80 seconds capacity with NANO Technology
This graph uses Real Test Data taken from an automated nitrous flow bench using 10 sec run time intervals.
The graph shows Horsepower vs. Run Time using both a standard Nitrous system with a 10 lb bottle and bottle heater, and a 10# Competition NANO System with no bottle heater. HP is calculated using a 5.2 :1 nitrous to fuel ratio. All data correlates to Nitrous Manager software by David Koehler. NANO systems develop 25% more average HP (Nitrous Mass Flow) than standard nitrous kits with the same jetting.
Test results show both systems performed about the same for the first 40 seconds of use. Beyond 30 seconds, the NANO system continues to perform at the 180HP level while the conventional systems performance drops quickly.
In practical terms the NANO system can achieve over 100% more run time without any decrease in performance until almost all 10 lbs of nitrous are used.
THE NANO 10 second advantage
NANO’s “mass flow technology” produces constant flow of nitrous oxide at all times. The results -
Constant Mass flow of Nitrous throughout the Run.
NANO systems develop 25% more average HP (Mass Flow) than standard nitrous oxide kits
This graph uses Real Test Data taken from an automated nitrous flow bench.
The graph shows Horsepower vs. Runtime for a 10 second run comparing performance of a Standard Nitrous system with the Competition NANO System. The bottle heater is not required for the NANO System.
HP is calculated using a 5.2 :1 nitrous to fuel ratio. All data correlates to Nitrous Manager Software by David Koehler.
Here’s what NANO users are saying:
“ … when I added NANO to my nitrous system my car came alive immediately, it really surprised people.”
“The days of loosing races because of low bottle pressure are over. NANO turns on instantly and provides the perfect bottle pressure in just seconds.”
Guest
Posts: n/a
This is the only extra part you need to add.
10# bottles
http://www.nitrousoutlet.com/catalog...roduct_id=1536
15# bottles
http://www.nitrousoutlet.com/catalog...roduct_id=1537
Guest
Posts: n/a
I am assuming you are needing another NANO 15# bottle and check valve....With the group purchase it would be cheaper to buy another kit, as the only other part is the hose.
Guest
Posts: n/a
DAMN RAY! I just can't get over the $6,000 it takes to do my bottles! I could do a blower for the price of NANO alone
It is a good deal guys do not get me wrong I just have ten bottles LOL!
Beside our Stim Check is getting the Wife new 383 out of the machine shop LOL!
Or you will need something like this, and a scuba tank
32 Degree cylinder refill station will attach your 3000 or 4500 psi paint ball cylinder to a high pressure scuba cylinder. It is equipped with both tank couplings and a mini gauge to read the pressure.
Scuba Fill Valve Special Order) - The scuba fill valve is a easy answer to gain access to a scuba tank for filling with compressed air. have seen them priced anywhere from $50-75
Guest
Posts: n/a
Just to let you guys know.....if you are wanting to get in on this you might want to hurry. NANO has a very limited supply left in stock and will have an unknown back order period once that supply has been depleted.
And we have met the 10 order minimum, so any order placed will be filled and shipped ASAP.
You need to check into the ability to fill your own NANO bottles....they sell a feild compressor that is a little over $3K.....but you might be able to rent one for the weekends you are going to go race. Some paintball shops will rent a transfer bottle that can refill a NANO bottle 50+ times in a weekend.
Ray can you PM the info. on where I buy everything I need to refill from a scuba tank? I have several scuba tanks already.
