Spraying An LS3 Based 427
Diamond pistons.
ARP studs.
11:1
If someone has advice on the topics of gaskets, compression ratio's, or camshafts I would love to hear.
Have a wet kit that is jetted for a 100 shot and (I know I say this now and it will probably change LOL) but that is all I intend on spraying.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Is there a way for me to get to 427 without using the 4.1 crankshaft?
Robert
Robert
3 things I am unclear about
1. CR
2. Camshaft
3. 427 vs 418
427 or 418, I would opt for the 427 as nothing can beat cubic inches. Are you looking at the stock l92 heads? there is some things concerning these heads and spraying.
Cons on spraying a 427, none as far as I can tell. If it's a dedicated build (IE:forged) there are a couple things you can ask for if you know what size shot you plan on spraying. If your planning on going big, then we need to adjust the ring gaps, and head studs come into play. Really, talking to your engine builder (as long as he understands n2o) is the best thing to do, especially after you get an idea of what you plan on doing, or rather your goals.
Robert
Robert
I plan on using compstar rods and crank-arp bolts.
What are the concerns with the L92 heads? As it sits now they are NOT ported-they are milled .030-stock gm valves, gen IV springs and titanium goodies with Yella Terra rockers. When I change over I will change the valves to stainless one piece and replace the springs, retainers, etc.
I would imagine you never plan on going "big" with a street driven DD and I really think with just a 100 shot it would get me to my et goal.
