Custom nitrous tune on pcm?
Old Jun 6, 2008 | 09:14 PM
BOTLRKT's Avatar
Question Custom nitrous tune on pcm?
Has anyone had there pcm tuned by a tuner for nitrous, not a handheld . I'm going to install a 150hp nx wet kit on a stock ls1 with a few addons and thinking of getting a tune if needed by a tuner. any info would be greatly appreciated. Thank You
Old Jun 8, 2008 | 02:11 PM
BOTLRKT's Avatar
looks like no one gets custom tuning for nitrous ,that seems odd with all these tuners out there doing tuning for different applications.
Old Jun 8, 2008 | 02:37 PM
SSPerformance's Avatar
bolt on car? just going to fix ur af and maybe pull 1 or 2 degrees out
Old Jun 8, 2008 | 03:04 PM
robsquikz28's Avatar
i hit mine all day with no timing retarded at all and the a/f was adjusted and that it.
Old Jun 8, 2008 | 04:01 PM
cbra-klla's Avatar
have your tuner tie into the other wire on your pcm and do a nitrous tune...when you go to spray, just ground that wire and you'll be set
Old Jun 8, 2008 | 08:53 PM
TrippleBlackC5's Avatar
www.trifectaperformance.com
Old Jun 8, 2008 | 11:04 PM
dnkynrbk's Avatar
I have a buddy of mine tune it. The biggest thing is retard your timming and and getting your air fuel correct get on a dyno. Or buy a wideband. Going to a 150 shot or higher you need to do one of these to be safe. Go with colder plugs.
Old Jun 8, 2008 | 11:30 PM
1966goat's Avatar
A timing retard would be better than letting the knock sensors pull the timing
Old Jun 10, 2008 | 12:22 PM
91rslt1's Avatar
Can anyone explain this in great detail? Such as which pin, how this works, who has done it, etc? I was thinking about going the Timing Tuner or MSD Timing Twister, but this sound like the best bet. Thanks
Old Jun 10, 2008 | 01:30 PM
JoeMama's GTO's Avatar
Currently an active thread https://ls1tech.com/forums/nitrous-oxide/934439-guys-who-wired-their-os5.html
Old Jun 12, 2008 | 11:23 AM
91rslt1's Avatar
Originally Posted by JoeMama's GTO
Thanks. now my question is what is COS 5?
