N2O baackfire = exploding hood.
I noticed the puff of smoke that came out of the tail pipe in the vid. I see it in the pictures you just posted as well. Have you checked your plugs? Normally when that happens its when you zap a plug or something lets loose. Have you checked the plugs and done a compression test?
If all is good. It may just have been the computer dumping fuel.
Dave
Dave
I figured I would install the new plugs when I do the compression test. Im going to buy the tool over the weekend and see how it goes.
I need to read up on it to see how to do it though.. I have never done it.
Doing a compression test is really simple. Screw the tool into the spark plug hole and turn the car over. Make sure the coil packs are unpluged.
Dave
Dave
Oh, and thanks for helping me do it.
Im pretty sure he probley also heard the back fire and the car probley ran funny for a minute why the computer struggles to compensate.
Dave
What you see is just some foam between the 2 pieces to help channel the air. In no way is it air tight and doesn't allow any air to go to other parts of the hood.
Only reason there was no fire is because I had no air filter in.
Hey Dave..
Here are my plugs.. These are from ......#3, 5, and 6.
It went lean do the the NANO bottle not regulating in my book... Like I said before, it was ~950 psi when I took off and when I got back to the pits it was~1300psi. I would imagine that that much of a pressure increase would cause a lean condition. Maybe the lean condition took out the plugs, then the extra fuel wasnt able to burn?? Anyhow, I talked with Brent (or Brett) over there and I sent him my bottle.
Im doing a compression test as well just to see how each cylinder is.
#1 = 210 #2 = 215
#3 = 205 #4 = 210
#5 = 205 #6 = 190
#7 = 210 #8 = 215
All pretty damn close but the piston #6, witch was one of the cylinders that had a fried plug.
I know we (Nitro Daves & full Throttle) had to get together to make the nitro dave WS and full throttles timing tuner work together. The schematic that was originally drawn up did not work. So, as far as I know, the new shcematic should have worked. Its programed to pull 4* for the 150 shot witch should have been enough. But, with the NANO acting up, whos to know if it just ran lean and melted the plugs or detonation from the timing tuner not doing what its suppose to.
Well, I think the only for sure way to see if timing is being pulled is to get it on the dyno and trick out the noids.. Just turn it up to 9* retard as that should be some noticeable HP loss.
Ill prolly see if the timing being pulled shows up on EFIlive... I have that and would have liked to have logged the run. But, the track guys get pissed if they see a laptop on the seat.
Robert
makes me worry about mine doin that
Let us know what the test came back with..Hopefully the diodes <-- Forget what there called right now..lol passed right through..
