N2O baackfire = exploding hood.
I was running a 150 shot, 4* of timing pulled and on 100 octane. When I came back to the pits, I noticed my N20 PSI was at ~1300. I am guessing I had a N20 spike due to it being to high. I did not have time/did not look at the AF guage yet to see where it was at.
I have had the 100 shot on for over 20 bottles and no issues at all. I only added the timing tuner and the NANO system since. I still cant get the N20 pressure below 1200 even after I try and purge it. So, I dont know whats up with that.
And sugestions on what might have caused it?
But, I understand what your saying though. The cheapy purge (forgot the name) I have cuts out at 1000PSI or so. I know the pressure was under that when I went thru the burn out box and took off. The pressure jumped up that much while going down the track. And, I let off at half track too obviously. I think something with the NANO regulator screwed up.
In all the runs I ran with the 100 shot it was set up at 3700 to activate and 6500 to shut off..
I changed it to 3300 to activate so I could hit the verter lower in the RPM and flash the **** out of it now that I have my 9" rear in.
I dont know what my AF was as I did not even look at it yet. I need to put some big *** letters in the car so I will remind myself to look.
no but seriously that dosn't make since how the hood would peel apart like that, i would understand a hood cracking down the middle and the intake in pieces but that's a strange way to break. probably the glue holding the hood finally gave out?
Dave
Im guessing the regulator/valve on the NANO is not working properly. I know it was at ~950psi when I turned it on. So, it went up that much in PSI from when I left till when I got off the gas.
Will the NANO guys give me another one? I think this one is not working.
Robert
You really have to keep an eye on anything that has only a regulator between the high and low side. They are reliable enough...but certainly not foolproof.
I am amazed that hood split like that and didnt screw anything else up. I bet it scared the crap out of ya!
Robert
