can i hide it here?
Old Jul 3, 2008 | 09:23 PM
cpe21's Avatar
Default help needed for stealth kit
i have a cts-v w/ the ls6.
i'm looking for a safe setup that i could hide as much as possible. my goal isn't to keep anything secret from competition, it's just that if i get pulled over and the cop pops my hood, nothing will appear out of the ordinary.
i've read about the "money maker", but i really can't find any info about it. i've also read that plate kits seem to be the way to go...but i'm not sure that i can hide one! i'd love to be able to keep everything hidden under my engine cover, if possible.
i would like to avoid the choice of a backfire, so i was thinking a dry shot would be good for me - buuuuut, my intake tube would give my secret away.
oh, i plan on hiding the bottle in the trunk (in the spare tire tub)...aaand i'm only planning to run a 100-125 shot (w all necessary accessories).
this picture is of my engine bay (well, not mine exactly, but the same car...i dont have a pic of mine, so i stole this one).
please advise.
Old Jul 4, 2008 | 12:49 PM
silverbandit0996's Avatar
the money maker kit is the pinnacle of stealth nitrous.
Old Jul 4, 2008 | 01:06 PM
krazy4's Avatar
Loom all of the lines and mount the solenoids under the engine cover.
That will work like a charm.
Old Jul 4, 2008 | 01:38 PM
16again's Avatar
I don't care if anyone sees my system either however I wanted my install very clean. I loomed all the wiring so you don't see anything.
I did not loom the 2 braided lines going to the plate. If I were to do so, you would see nothing.
Old Jul 4, 2008 | 01:39 PM
16again's Avatar
For the record here are the noids BEFORE the covers were put back in place. Good Luck with your system and install.
Old Jul 4, 2008 | 10:51 PM
Oso SS's Avatar
i've learned if you black tape and wire loom everything, MOST people won't be any wiser to your set up and you can leave your hood popped all night.
even with blatantly obvious kits you can do this. Most people don't know what to look for.
If you REALLY want to go stealth, get the moneymaker.
Old Jul 5, 2008 | 01:04 AM
myfast70's Avatar
You can use the money maker kit just as a dry setup and the use the HSW interface for the fuel compensation.
Old Jul 6, 2008 | 01:23 PM
cpe21's Avatar
thanks for all the help and pics, guys. so it looks like there are a couple of ways to keep things hidden from the police!
regarding the money maker...people keep mentioning the name, but no on seems to be explaining it. what are the specifics of the kit?
Old Jul 6, 2008 | 01:33 PM
sslateron's Avatar
Your worried about a cop pulling you over? When is NAAAAAAAWZ illegal? (I couldn't resist!)
Old Jul 6, 2008 | 01:49 PM
cpe21's Avatar
not sure i understand your comment, but i'll try...
yeah, nitrous is illegal if the bottle is hooked up...since i plan to keep it hooked up at all times and use an remote opener, it will technically be illegal for me to have it on the streets.
i got a huuuuuge ticket a few years back for simply having modified my intake tube! i just want to keep my engine looking as stock as possible in case a cop hears my exhaust and decides that he must take a look under my hood - which is what happened last time.
btw, i'm not sure anyone here referred to n2o as nos.
Old Jul 6, 2008 | 01:53 PM
JL ws-6's Avatar
Race your car!
If you run a dry kit you can put the nozzle on teh bottom side of the intake tube and run the single line/solenoid anywhere you want. Noone's gonna see that, especially if ya put the line in some loom.
Old Jul 6, 2008 | 01:58 PM
Oso SS's Avatar
it's a completely hidden nitrous kit. completely hidden. COMPLETELY. meaning that NO ONE will find it unless you tell them about it.
your car will look 100% stock under the hood, cops sure as **** won't see it.
i posted these pics on a HUGE mustang board and no one could find the system in the pics. maybe they just didn't care because I didn't hide it well at all, but if it's a foreign motor than you're used to looking at, you're just not going to see it unless it's jumping out at you (through NOS, NX, TNT and the like stickers)
all this had was black tape and wire loom and the solenoids out in the open.
the first pic is obvious as ****, and you could even hide that more by black taping over the nozzle (i didn't for ease of jet change) or just put thicker loom over the whole thing.
Old Jul 7, 2008 | 11:25 AM
cpe21's Avatar
awesome info, thanks a lot guys, that really helps a lot!
Old Jul 7, 2008 | 11:45 AM
JL ws-6's Avatar
Race your car!
Easiest way for your car is to just put it in the bottom of the airbox, you could put the solenoid in there with the nozzle right off the solenoid I'd guess, then run the 2 wires out the bottom of the stock airbox with the feed line. Now you've got the whole thing, solenoid and nozzle inside the airbox. Probably not the mose effective way but it will work and noone's gonna see it that I'm sure of.
Some black shrink wrap or tubing around the feed line, and add a layer of sirink wrap around the wires to run them inside the car to a power source and a activation switch and you'd see absolutely nothing.
Yes, I've helped more then one person hide a kit on their car in the past
Old Jul 7, 2008 | 12:42 PM
batboy's Avatar
Yeah, JL is dead on. Just put the solenoid and nozzle in the air box. Simple to hide a dry kit. You will need to have it tuned of course. Plastic wiring loom conduit that you can buy at any auto parts store is great for hiding feed lines.
Here is a link that shows my stealth dry system. I have a GTO, so it's not exactly the same, but it should still give you some good ideas.
http://www.ls1gto.com/forums/showthread.php?t=239436
Old Jul 7, 2008 | 07:34 PM
krazy4's Avatar
Wire loom F T W!!!
Old Jul 7, 2008 | 08:02 PM
Nitro Dave's Nitrous Outlet's Avatar
Making any system on your set up not as noticeble would be very easy to do..
As a FYI Dry systems have back fires as well.
Here is a good tech read to help build knowledge
http://www.nitroustech.com/forums/showthread.php?t=92
Let me know if I can help you in any way.
Dave
Old Jul 8, 2008 | 07:26 AM
Noyzee's Avatar
8 second mod
the money maker is hidden like no other
Old Jul 8, 2008 | 07:41 AM
jmill96Z's Avatar
If I were you, I would go with a dry nozzle and the Interface. You could put the nozzle on the bottom side of the intake tube, before the TB, by that band clamp. Nice, easy, stealth setup.
Old Jul 8, 2008 | 03:16 PM
TwistedSS's Avatar
You cannot hide any nitrous kit on an LS1. No one has ever done it. Ever.
