Plate users I need help!
Old Jul 6, 2008 | 03:26 PM
99ccz28's Avatar
Default Plate users I need help!
I have a HSW plate kit on my car. Those of you running a plate, did it screw your tune up? My car is running like crap, it is way lean, hard to start sometimes and stalls sometimes. Fuel pressure is good. Just seeing if any of you have had a similar problem.
Old Jul 6, 2008 | 03:44 PM
Mike@HSW's Avatar
you dont need a tune when you just hook up the plate. sounds like you have a vacuum leak somewhere
Old Jul 6, 2008 | 03:48 PM
99ccz28's Avatar
I've looked but can not find one anywhere. Is there a way to check for a vaccum leak other than just looking?
Old Jul 6, 2008 | 03:49 PM
RZRSEDGE's Avatar
X2. Sounds like a vacuum leak, maybe leaking where the plate seals to the throttle body or the intake.
Old Jul 6, 2008 | 03:50 PM
RZRSEDGE's Avatar
Ever have a high idle?
Old Jul 6, 2008 | 03:54 PM
99ccz28's Avatar
Everytime I start it. That is what I thought at first but I dont know where
Old Jul 6, 2008 | 04:02 PM
SuperSlow02's Avatar
sounds like a big ol leak. Id just double check everything, It seemed like i had a slightly higher idle when i installed mine. It seemed to worked itself out though.
Old Jul 6, 2008 | 04:33 PM
99ccz28's Avatar
I just sprayed everything with cleaner and had no change in the engine rpm.
Old Jul 6, 2008 | 05:00 PM
Mike@HSW's Avatar
how tight did you torque down the bolts?
Old Jul 6, 2008 | 05:10 PM
1320 killer's Avatar
i use a nitro daves plate and i havn't had any problems with it.
Old Jul 6, 2008 | 05:48 PM
99ccz28's Avatar
I don't have a torque wrench but they are tight. I took it apart and put it back on and same thing.
Old Jul 6, 2008 | 07:10 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
Take it off and see if the problem goes away. IF it does, put the unit back on and see if the problem comes back.
Old Jul 6, 2008 | 07:24 PM
Mike@HSW's Avatar
Give us a call tomorrow and we'll set you straight.
Old Jul 6, 2008 | 08:17 PM
99ccz28's Avatar
well, i was going to take it off but once i did that i come to the conclusion that i dont have the stock tb bolts
Old Jul 6, 2008 | 08:23 PM
99ccz28's Avatar
thanks mike. I have no doubt that if it has anything to do with the plate you will take care of it.
Old Jul 7, 2008 | 08:35 PM
00silverGTP's Avatar
I had the high idle and it was b/c the throttle cable bracket was a little off, bent it in slightly and released the pressure.
+1 on the leak though
