schrader valve for fule
Old Jul 7, 2008 | 10:13 PM
LTLRDSS's Avatar
Default schrader valve for fule
as far as nitrous goes i know that i want to go with a plate kit, and iv been searching and see that everyone is using the schrader valve off the fuel line to supply the fuel. obviously it works and im not trying to say it dosen't, but how do you still have equel fuel pressure to all the injectors, dose the pump supply enough fuel to keep the pressure up. just wondering becouse i would think that fp would go down because of that, if some one could shine some light on it thanks
Old Jul 7, 2008 | 11:48 PM
SuperSlow02's Avatar
everybody uses it so id imagine the FP keeps more then enough pressure up there for stockish engines.
Old Jul 8, 2008 | 05:54 AM
Beer99C5's Avatar
I log fuel pressure, I have seen drops from 62 PSI to 35 PSI. Longest I seen it last is .7 sec. As long as the pump recovers I am told its OK.
WOT NA I usually see 62 PSi drop to mid 50's and recover.
Old Jul 8, 2008 | 08:28 AM
rpmauto's Avatar
worked just fine on my stocker, with a 255 pump and hotwire kit, now with my 402 i am not sure it will be a good idea. I will find out on the 30th when she gets tuned.
Old Jul 8, 2008 | 05:36 PM
02NBMWS6's Avatar
I did not like this setup either, so I just went ahead and set up a standalone fuel cell. No worries whatsoever now And C16 in the cell..
Old Jul 8, 2008 | 09:44 PM
LTLRDSS's Avatar
ok thanks for clearng things up, beer are you on a stock pump
Old Jul 9, 2008 | 05:41 AM
Beer99C5's Avatar
Racetronixs w/ Hotwire Kit
Old Jul 9, 2008 | 11:10 AM
Chris@NitroDaves
Guest
Posts: n/a
There will always be a pressure drop weather you are NA, Boost, or Nitrous. As long as the drop isn't longer than a split second and the pump recovers pressure you will be fine.
-Chris
Old Jul 9, 2008 | 07:51 PM
n2ocamaro's Avatar
My fuel pressure was bouncing back and forth on a 100 shot (410rwhp on motor) from the shrader valve with 255 Walbro and hotwire kit. So I added a 2nd Walbro intank pump. Now the pressure stays rock solid.
Old Jul 9, 2008 | 08:04 PM
00cls1camaross's Avatar
If we move the fuel pressure regulator will it be better?
