Disapointment
Old Jul 11, 2008 | 11:49 PM
SScott's Avatar
Default Disapointment
I did a few test runs with nitrous and without. I can't say I notice much of a difference at all. Bottle pressure is good, everything is connected and wired right. I don't know but I'm not impressed at all. I'm only running a 125 shot right now, but I was expecting a little more.
Old Jul 11, 2008 | 11:57 PM
jetlag's Avatar
What is your air fuel ratio? When I did a few test runs, my car was going lean and making the car run like crap.
Might want to check your plugs..cause you'd definitely feel a 125 shot.
Old Jul 12, 2008 | 12:19 AM
SScott's Avatar
I wouldn't say the car runs like crap. It just doesn't seem like it's any faster, but it's running and drives like it always does. I have a wide band on order, hopefully. I'm going to take it back to the shop and throw it back on the dyno and see whats going on.
Old Jul 12, 2008 | 01:08 AM
SSmoken's Avatar
well dont expect it to look all blurry when you hit the switch lol.
Old Jul 12, 2008 | 02:51 AM
SScott's Avatar
No? Damn I was hoping for the blurry.
Old Jul 12, 2008 | 03:09 AM
508Stroker's Avatar
yeah you should easily notice a 125 shot. Makes a lot more tq too. Something is probably up.
Old Jul 12, 2008 | 03:11 AM
RedsrtAk's Avatar
How is the bottle mounted?
I didn't have it at much of an angle for a couple runs....didn't seem as if it hit very hard, tilted it back more to make sure the syfan tube picked up all the nitrous and it felt as if it was a night and day difference.
You should definitely be able to feel a 125 hit. If thats not the case wait for the wb to check AFR's etc.
Old Jul 12, 2008 | 03:50 AM
jmill96Z's Avatar
Tell us some more about your setup. You should definately feel a 125 shot hit like a freight train. Did you ops check the system, or just wire it according to a schematic hoping that it works?
Old Jul 12, 2008 | 07:25 AM
ShiznityZ28's Avatar
Put a 2nd 300 stage on it and youl get alittle blurry. LOL
Sometimes it helps if you grip the wheel real tight and make bruum bruum noises while spraying. .......
Old Jul 12, 2008 | 10:54 AM
Pharcyde50's Avatar
Sounds like your system might not be operating correctly. A 125 shot should hit pretty good. I would probably back down to a smaller shot and make sure everything is working correctly. I know when I first had juice on my car I was like wtf this sucks turned out the system wasn't even spraying.
Old Jul 12, 2008 | 10:57 AM
BAKED's Avatar
You do that too!
I thought I was the only one.
Old Jul 12, 2008 | 11:09 AM
SScott's Avatar
Theres got to be something wrong cause I already do that, and I go screeeeetccchhhhhhh when I go around corners. No blurry. =(
Old Jul 12, 2008 | 11:16 AM
edcmat-l1's Avatar
Cant be working at all. A 125 shot is a nice kick in the *** on a basically stock car. If it were malfunctioning and only spraying fuel, it would perform worse than without it. Only spraying N20 and your motor goes pop.
Old Jul 12, 2008 | 12:54 PM
Black2001z06's Avatar
Yup, you've definately got something wrong.
A 125shot should put you back into your seat!
Time to start troubleshootin...
Old Jul 12, 2008 | 02:09 PM
Sounds like its not aprayin at all. you should notice a 125 shot.
Old Jul 12, 2008 | 03:27 PM
00cls1camaross's Avatar
pull the nozzles off and spray them into a bucket and see if it is actually spraying
Old Jul 12, 2008 | 03:53 PM
SScott's Avatar
The wire connections to the WOT switch were loose (but not disconnected) I reattached then more securely and am going to try it again.
Old Jul 12, 2008 | 03:54 PM
SScott's Avatar
I have a forged 408 putting 500+ to the wheels on motor.
Old Jul 12, 2008 | 06:10 PM
BAKED's Avatar
You should still feel it, no doubt about it.
Old Jul 12, 2008 | 07:05 PM
BOLO's Avatar
125 shot on top of 500+rwhp should be a big kick in the ***!
