SPONSORS PLEASE...Looking to buy NOS set-up
Old 09-30-2008, 09:54 AM
dankl's Avatar
Default SPONSORS PLEASE...Looking to buy NOS set-up
Like the title says, looking to buy a NOS set-up. I am leaning towards the wet plate kits. I have a FAST 92/92 combo, so it will have to work with this TB. All my mods are listed in sig. I'm thinking 150 shot should be fine, but I'm open to suggestions. Also, what "extras" do I need/should I get. I want to be safe, so any extras that are for being safe in case of malfunction I'd be interested in. Looking to build a list of parts or kits to purchase immediately.
Thanks guys, I look forward to your responses!
Old 09-30-2008, 09:59 AM
Mike@HSW's Avatar
here is a link to our 92mm wet plate kit. Only plate on the market with a full 360 degree conical spray patern that produces the least intake turbulance and most even distribution of nitrous and fuel to the intake
http://www.harrisspeedworks.com/shop...cat=398&page=1
in addition to that i would recommend our "all out kit" that includes a lot of accessories that would enable you to run a safe and reliable setup
http://www.harrisspeedworks.com/shop...age=1&featured
here is what it comes with
HSW MicroEdge Nitrous Controller
Nitrous Bottle Heater Kit
Nitrous Purge Kit
Nitrous Oxide Bottle Blow Down Tube Kit
Billet Nitrous Filter Kit
NGK TR6 Spark Plugs
If you have any questions at all don't hesitate to PM me or give us a call
Old 09-30-2008, 10:28 AM
dankl's Avatar
Looks good. Is this everything I would need? Do I need a switch plate like; " '98-'02 Manual Camaro/Firebird Ashtray Switch Plate" also?
Also, for the bottle heater: 4AN or 6AN ? What is the difference between the two and which should I go for?
Thanks again
Old 09-30-2008, 10:40 AM
dankl's Avatar
Ok, I have these in my "shopping cart". Is this everything I'll need? Does this include everything needed for install? Basically I want to know if I have this package sent to my mechanic, is this everything they will need to set up the NOS?
HSW All-Out Nitrous System Accessory Kit
HSW Sudden Impact 92mm EFI Wet Nitrous Plate Kit (92mm LS1 F-Body | C5 Corvette)
Plate Kit Style: LS1 F-body
Also, are there any "coupon codes" for us LS1Tech.com members?
Thanks for all the help.
Matt
Old 09-30-2008, 11:10 AM
Nick@HSW's Avatar
Thanks again
Matt,
It isn't required but it will definatly help with the install. Plus they look pretty good.
You would want the 4AN bottle heater.
Nick
Old 09-30-2008, 11:12 AM
Nick@HSW's Avatar
Matt
Cart looks good! The only things missing would be convenience items such as remote openers, billet bottle brackets, etc. Anything else just let either of us know. Thanks!
Nick
Old 09-30-2008, 11:20 AM
myfast70's Avatar
Matt
You'll be very happy with this setup! Be sure to post some pics once it's installed.
Old 09-30-2008, 11:52 AM
dankl's Avatar
Remote Bottle Opener added to cart. Definitely want to open the bottle from drivers seat. Anything else I should check out before ordering? The billet bottle brackets mentioned, are these just for looks? I don't really care about the looks right now, just want to have everything I would need to set this bad boy up without having to order miscellaneous parts that were over looked.
Old 09-30-2008, 12:32 PM
Nick@HSW's Avatar
The billet bottle bracket serves two purposes. First is looks and the second being ease of use. Its a lot easier to pull 2 pins than it is to undo the standard bottle brackets. Other than that you're all set! Thanks!
Nick
Old 09-30-2008, 05:27 PM
SuperSlow02's Avatar
Im running that exact kit..well everything cept the HSW switch panel, didnt get it out in time . Anyways, like they said, youll be extremely happy with this kit. I would suggest the Revolution bottle heater, that kit is awsome. O yea...buy extra bottles lol.
Nick you guys should start making extra bases for the bottle openers, too much hassle to swap from bottle to bottle
Old 09-30-2008, 06:15 PM
myfast70's Avatar
Unfortunately they are on back order
Old 10-01-2008, 09:41 AM
dankl's Avatar
Thanks guys. Anything else you would recommend before I place my order?
Old 10-01-2008, 09:49 AM
dankl's Avatar
Anyone running a timing tuner?
Old 10-01-2008, 09:51 AM
Nick@HSW's Avatar
You have everything covered! Thanks.
Nick
Old 10-01-2008, 09:52 AM
Nick@HSW's Avatar
You can run a timing tuner with everything else you have listed. The only thing that you wouldn't use is the window switch feature on the timing tuner. Another option would be to pull the timing out with your tune.
Nick
Old 10-01-2008, 10:51 AM
fstphx's Avatar
Hey Nick- What will these plates flow up to with larger jets?
I am looking for something to flow quite a bit more than 150 on a 92mm...
Old 10-01-2008, 11:32 AM
Nick@HSW's Avatar
Hopefully you got my PM I sent back? If not...for the 300 shot you're looking to spray, I recommend a direct port. Thanks.
Nick
Old 10-01-2008, 12:17 PM
fstphx's Avatar
I did- Just didnt get a chance to shoot one back- thanks
