Infocus X1 DLP Projector: $399
I bought this beast for $900 a year or so ago and I hardly use it. Its got AWESOME picture quality. Comes with carrying case, and HD component Input cable.
Got 4.5 stars at Amazon.com
1,000 ANSI lumens, 2,000:1 contrast ratio
Native 800 x 600 SVGA resolution
Compatible with SVGA, VGA, XGA, Macintosh
Weighs just 6.8 pounds
You can hook this projector up to a VCR or Cable box, DVD player or computer. I even played Xbox games on it!
$399 plus shipping.
Thanks for looking!
Some specs on the X1:
Projection technology DLP, with one matrix and 4-segment (RGBW) color filter with double speed of rotation
Matrix micromirror (DMD), 0.55", DDR, 12 degr. tilt
Matrix resolution 800x600
Lens 1.2x zoom
Lamp 150 W, DC SHP
Lamp service life 3000 hrs, but it needs to be replaced after 2000 hrs
Light output 1000 lm (ANSI), sometimes 1100 lm is specified
Color depth 16.7 M colors
Contrast 2000:1 full on/full off
Projected image size, diagonal, 4:3 (distance to the screen at the zoom extreme values) min. 1 m (1.5-1.8 m)
max. 5.1 m (7.7-9.3 m)
Inputs Video, composite, RCA
Video, S-Video
Video, component, 3 RCA (with adapter)
Video, VGA, mini D-sub 15 pin
Video, SCART (with adapter, only composite)
Audio, USB stereo minijack
Outputs Video, VGA, mini D-sub 15 pin, "monitor out"
Scanning frequency horizontal 31.5-80 kHz
vertical 50-85 Hz
Input signal formats TV: NTSC, PAL, SECAM
compotent video signals Y/Cb/Cr: DVD (only 480i/576i)
analog RGB signals: VGA, SVGA, XGA, HDTV (1080i, 720p and 480p RGBHV)
Noise level 37 dB
Integrated audio system mono, 2.5 W
Dimensions 318x249x114 mm
Weight 3.1 kg
Power consumption 200-250 W
Power supply voltage 100-240 V, 50-60 Hz
Lens 1.2x zoom
Lamp 150 W, DC SHP
Video, S-Video
vertical 50-85 Hz
Noise level 37 dB
Weight 3.1 kg
