RCA HD56W66 56-Inch Diagonal HDTV
I have only had this TV a short time and it got bumpped now the picture is off... it curves in at the top and bottom, just dont have the time or the money to mess with it, the place i bought it from wont fix it for free so i will just take a 400$ loss for someone to get a brand new TV it is a 2007 model
ASKING 850.00obo Will ship, and might meet for local pickup
The RCA HD56W66 56" Diagonal High Definition Television Built-in ATSC Digital Tuner delivers off-air reception of local HDTV and digital broadcasts with just the addition of an antenna (sold separately). DVI-HDTV allows transmission of (uncompressed digital) video signals from a set-top box to a digital TV. DVI delivers the purest digital transmission available today.
Synergistically optimizes picture performance by synchronizing advanced signal processing, display technologies and HD connectivity. Separates black-and-white detail from color information to virtually eliminate edge crawls and rainbow effects while enhancing picture resolution.
Graphic equalizer w/expanded stereo processing provides a rich "live performance" experience. Audio outs simplify connections to home theatre systems. TV can easily be moved on its 4 swivel casters. Unique angled backcover contours provide more living spacethe room by fitting closer into room corners.
Features:
* Integrated ATSC Tuner
* Hi-Pix™ Picture Systems with TruScan Digital Reality™ Intelligent Signal Processing - "Because the Picture Intended Should be the Picture Presented
* Digital 3-Line Comb Filter
* HD Connectivity with DVI-HDTV
* Two Sets of Composite Inputs (V+L+R +S-Video) Plus Two Sets of SYNCROSCAN™ Component Inputs (YPbPr+L+R).
* Advanced Audio Capabilities Including 5-Band Graphic Equalizer, Two Pair of Audio Outputs and Subwoofer Out
* Unique Lightweight Cabinet Design Weighing Less Than 165 Lbs.
Specifications:
BRAND RCA
Screen Size - diagonal (inch) 56
Category HDTV
Aspect Ratio 16x9
CRT / Light System AVR™ CRTs
1st Surface Reflective Mirror Yes
3:2 Pull Down Reverse (On/Off/Advanced)
Adjustable Color Temp Yes
Adjustable Picture Control Yes
Auto Color Balance (AKB) Yes
Automatic Letterbox Detection Yes
Blue Boost Yes
Color-Corrected C Elements Yes
Comb Filter Digital 3-Line
Contrast Expand (B&W Stretch) Yes
Convergence Intellifocus™ Digital Auto
Dynamic Focus Yes
Edge Replacement Yes
Format Control Yes
Horiz Resolution (Picture Width) > 1200
Hybrid Lens System AVR™ 4-Element
Picture Power (watts) 42
Picture Presets 5+Personal
Pix Tube Pitch 0.52mm (Screen)
Progressive Scan / Scan Rate Converter Yes - TruScan Digital Reality™
Protective Shield Yes
Scan Velocity Modulation - SVM Yes
Screen Type Optimum Contrast, High-Resolution
Video Noise Reduction Adaptive
Viewing Angle - Horizontal > 82 degrees
Wide Band Video Amplifier Yes
Audio Processor Expanded Stereo w/Bass Boost
Balance Control Yes
Front Speakers (number) 2 - Full Range
Headphone Adjustments w/Main Volume
Second Audio Program (SAP) Yes
Sound Logic™ Audio Leveler Yes
Sound Presets 7 Modes + Personal
Sound Type Broadcast Stereo
Tone Control 5-Band Graphic Equalizer
Total Watts 20
Channels / Watts 2 Channels, 10 Watts Per
Tuning Capability NTSC/ATSC
Digital Cable/Satellite Connections DVI / HD Component
Features:
Specifications:
BRAND RCA
Category HDTV
Aspect Ratio 16x9
Blue Boost Yes
Dynamic Focus Yes
Format Control Yes
Balance Control Yes
Total Watts 20
Tv
Good luck with the sale!!! I just looked it up online and you can get it brand new for 793.00...might think about dropping to get rid of it...thats what sucks about electronics...you never get your money out of them...
i have been told you can adjust it by taking off 4 bolts... and adjusting the bulbs? I am not going to mess with it... there is alot of electricity in there and i would fear i would mess it up more... Local tv guy wants 100$ to look at it...
