Northwest Members WA, OR, ID, MT, WY, SD, ND
how hard is a cam swap?
Old 02-12-2011, 09:57 PM
firechicken76's Avatar
Default how hard is a cam swap?
ive got all my parts together, and was wondering if trying to do this by myself would be a good idea or not. 02 ls1 in an 88 trans am. have the cam, springs, pushrods, timing chain, gaskets etc....
Old 02-13-2011, 10:48 AM
*02WS6TURK*'s Avatar
Never done one myself. However, if you don't feel comfortable doing it yourself I would recommend calling Tom Wong @ Wong's Performance. He did a great job on my cam swap and tuning as well. (360) 695-9433
Old 02-13-2011, 10:54 AM
msydow's Avatar
super easy. right tools are the key. first one i did was a biotch. use the correct balancer puller/installer and a good valve spring tool such as the comp cam 5462 valve spring compressor. you will need air to pressurize the cylinders while changing the springs. impact makes crank bolt removal a breeze also. anyway...have fun.
P.S. what cam you putting in?
Old 02-13-2011, 11:06 AM
freefallen.1's Avatar
I have done a tone of them. Would you like a pm with the step by step directions or does everyone want this information.
Old 02-13-2011, 11:18 AM
projectX's Avatar
Shoot you can pm me with steps to do it.
Old 02-13-2011, 11:24 AM
MyFirstLS1's Avatar
ls1howto.com
Old 02-13-2011, 11:30 AM
cali_bear2003's Avatar
I would Very Much like to have the step by step or information.........
Thanks....
Old 02-13-2011, 11:33 AM
Looked at the ls1howto write up. Very good with detailed pictures. You can use this but will need to adjust a few things for your 3rd gen.
Old 02-13-2011, 11:41 AM
Mikey 97Z M6's Avatar
What you're asking is a relative question. How familiar are you with working on cars? What is your comfort level for taking complicated things apart and putting them back together again? Do you have a budget set aside in case things don't go as planned?
These are all things I thought about when I was a lot younger and just learning about engines/cars etc..
Mike
Old 02-13-2011, 12:54 PM
Im actually planning on him doing the tune for me when I get it in there,Im just trying to get a feel for how hard it is, so i dont have to spend the extra money having someone else do it.
Ive got a shop with air, probably have the valve spring tool down there too. How about the lifters? should i invest in the tool that keeps them held up? or just use the russian roulette method? (Just checked out ls1howto)
I went with the Lingenfelter GT2-3 cam, the specs are
207/220 573/.580 w 1.7 rocker 118.5 CL. The reason I went with this cam is that I Have a magnacharger sitting in my garage that I plan on installing after I get the cam in.
Mike
I did my header install, ac removal, air removal, Ported tb install, and a few other minor things, nothing bigger like this, I Im trying to get someone down there that has some expirience with this to kinda supervise me while i do it lol. Ive got money set aside for a tune, so i guess that could be considered set aside if something goes wrong....i guess that depends on how wrong it went :p
Old 02-13-2011, 11:55 PM
Anyone know of any other dyno tuners? maybe in tacoma or seattle? I looked up wong, he is just too far of a drive, thats about a 3 hour drive for me each way.
Old 02-14-2011, 04:46 AM
SalvageZ28's Avatar
LOL its not that bad of a drive man=)
Old 02-14-2011, 09:22 AM
If you want the best work/tune possible, then the 3 hour drive should be the last thing on your mind
Old 02-14-2011, 11:50 AM
98goldz28's Avatar
Wong is the man when it comes to Tuning or anything GM performance. I would not let anyone else tune my cars/truck. He is about a 3 hours drive for me as well but is well worth it IMO
Old 02-14-2011, 12:40 PM
1badSS's Avatar
As far as the lifters,I used a wooden dolrod from home improvement store I think it was 5/16, cut to 22 in's long. I did a search on hear to get the correct info, some people talk $hit about it. But it worked well for me with no problems. As far as the valve tool I bought a 8 dollar one from autozone amd moded it like the one shown on ls1howto.com it worked well, took awhile to do each spring but I saved the cash on the tool. hope this helps, the job itself is not that hard.
Old 02-14-2011, 01:05 PM
does anyone know about the trifeca company?
Old 02-16-2011, 01:48 AM
stangtrader's Avatar
Yeah vince is supposed to be good but he's been out of town was gonna use him but instead used Ellis at speed secrets. You looking for
A mail order or local?
Old 02-16-2011, 01:49 AM
Oh just looked thru LOL call Ellis at speed secrets he's a stand up Guy and got it running great.
Old 02-16-2011, 02:16 AM
02sslayer's Avatar
call ellis. i didnt have my car tuned by him but i have heard nothing but great things about him. he is alot closer to your location
Old 02-16-2011, 09:17 AM
Rockin C Racing's Avatar
Last I knew, I don't think Speed Secrets (aka Ellis) has a dyno. The original poster did say dyno tune. Just FYI
Quick Reply: how hard is a cam swap?
