The surgery begins
And I made the inner cooler exhaust vents. The inner coolers are tucked into the front corners, with scoops on the bottom. But the air flows into an enclosed area. So I cut the vents out of the plastic pieces you remove for the inner coolers & put them in the wheel wells to let the hot air out.
I took a couple pics. After I clean up & go inside I'll post them.
