Northwest Members WA, OR, ID, MT, WY, SD, ND
need to find a new rear end
Old 03-17-2006, 10:13 PM
krazzycowgirl's Avatar
Default need to find a new rear end
My brother in law suggested I just get a new rear end for my car he either suggested a 9in ford rear end (something I am not really wanting to put in to my car lol) or a nice 12 in that will fit in my car.
anyone know where I can get one built for my car?
Old 03-17-2006, 10:29 PM
TwoFast4Lv's Avatar
I know where there is a nice 12 bolt out 0f a 4th gen for sale.
We will NOT be giving it away but it will be cheaper then a new one.
It has 3.4xs in it and will take 4th gen wheels
Old 03-17-2006, 10:37 PM
how much ellis?
but wouldnt 4th gen rear end stick out of the 3rd gen?
Old 03-17-2006, 10:44 PM
T is for Towing not Turbo
silverbullet02's Avatar
Is something wrong with your stock one or want one just for the heck of it?
Old 03-18-2006, 12:11 AM
Nothing is wrong with it its just with the engine & up graded HP I have a feeling that the stock rear end will not hold up lol
Remember this is for a 87 Iroc 355
Old 03-18-2006, 12:39 AM
Poik's Avatar
How much power are you looking at? I thought you were running ~14.7 the last time the car ran?
Old 03-18-2006, 01:10 AM
I was but that was when the car was a stock 350 with the stealth ram on the car now its a 355 wtih the stealth ram on it & the guys that built it said the car MAY go 12s. Will not know for sure until I get the car up & running which may not be until next year, I still have a few K to spend on just the engine alone & the new Computer system that was suggested by Don.
You guys have to also remember that was with street tires & me starting from Idle when I boosted the car up to even 1000RPMs the car went sideways off the line.
Old 03-18-2006, 01:13 AM
Amorget's Avatar
how much ellis?
4th gen rear adds a couple inches on both sides. Options: Run it as is, it isn't that horrible. Or get 4th gen offset rims, and spacers in the front.
Old 03-18-2006, 01:25 AM
slowcamaro's Avatar
i am interested if you want to give me a pm
Old 03-18-2006, 09:58 AM
AndreS's Avatar
my feelings on this go back to the old saying:
why fix that which isn't broken?
what breaks in the 10 bolt rear usually anyways?
Old 03-18-2006, 11:06 AM
Amorget's Avatar
Normally they are issues with flex and the ring and pinion blowing up
Old 03-18-2006, 11:15 AM
Rottluver's Avatar
Did you do something else to it besides add 5 cubic inches? Not trying to be mean but rarely does 5 ci equal a 2+ second change in ET's.
Mine died a tragic & young death due to numerous component failures/ breaking.
Old 03-18-2006, 01:14 PM
NWDragRacer's Avatar
I agree. For a lot less than the cost of a new rear, you can upgrade the stocker to handle 12s without much problem. Here's what you need to do...
1. Replace the crush sleeve with a solid spacer. This keeps the pinion from being sucked into the ring gear and causing clearance (read: destruction).
2. Add one of the aftermaket rearend support covers. They come with carrier support screws that keep the carrier from moving back and causing clearance (see above). Summit has one for $150.
3. Weld the axle tubes to the center section. Dan at Differentials NW can do this.
4. Add C-clip eliminators. Summit has them too. This will keep the wheel in the wheelwell if the axle breaks.
I did these upgrades on the Duece's 8.2 rear and made at least a hundred drag strip passes with the Richmond 6-speed and Nittos. It held up until I got to Mission and tested their legendary traction. The pinion snapped off.
Old 03-18-2006, 01:22 PM
Thanks Don This is the information I needed.
My order from summit is going to be small this month but WIth it the engine will almost be complete & ready to in stall then I get the TC & the pulleys when we are down in Reno. Doing an engine on a really tight budget (only a couple 100 a month is madding) So as I said before the car is another year out.
Old 03-18-2006, 07:43 PM
Amorget's Avatar
So, uh, Ellis, is that 12 bolt a TCS/ABS rear or just ABS?
Old 03-18-2006, 10:04 PM
TwoFast4Lv's Avatar
Add to this the fact that every year if you race it you will STILL need to have a new set of bearings in it and if you are running a PR every other year you will need a ring and pinion
Lets face it the rear end was designed for a Vega and a four cylinder. By the time I got my 12 bolt I have spent over $3k on my ten bolt.
This rear end is for sale with a heavy heart from the owner who needs money to pay bill's and will have to be replaced at a later date but that is how life revolves.
We are asking $1,800 or resonable offer. We will ONLY sell local and ONLY to an Automatic car. If you have a stick you need a 9in or a Strange Dana SD60.
You can buy a new stripped down Spool Unit for $1,790 PLUS shipping. This unit has the HD Eaton and is set up for TCS/ABS. Buyer can ride in car before buying.
Old 03-18-2006, 10:27 PM
Amorget's Avatar
Old 03-18-2006, 11:31 PM
TwoFast4Lv's Avatar
Originally Posted by Amorget
I could Lie to you and let you break it
Old 03-19-2006, 08:51 AM
My1st Truck's Avatar
Yeah, 9 inch or 60 in a 6 speed. I learned my lesson, the exspensive way.
Now the Trans Am is retired, becuase all I have in their is the 10 bolt, altough recently it has held up to some spirited (read N20) driving...
Old 03-19-2006, 11:56 AM
AndreS's Avatar
cool thanks for answering the question....
for my swap car i may end up throwing a ford 8.8", 9" or mopar 8.75" in it eventually anyways. I believeI don't have to cut down a maverick 9"(if i can find one)... but i could be wrong.
Quick Reply: need to find a new rear end
