Need Help with Bad Vibration
I have a real bad vibration in my car that you can feel pretty much from 2000 RPMs up. I recently put in a new transmission with a TCI Flexplate and TCI Stall, and have had a custom driveline made to fit the car, and had all wheels balanced.
My biggest question is... The TCI Flexplate came with a metal sleeve that fits over the Stall and into the Flexplate. When I tried to install with this bushing my tranny housing was 1/4 inch off the motor, and when I called TCI they said that it was only need if I wan't using a TCI Stall. I've sinced called TCI 3-4 times and each time got different answers as to when this part is needed. I've been told it's needed on all LS1/tranny, only with an LS1/TH350 or 400, only when used with a TCI stall.
Does anyone know what this piece is for?
Any other ideas on what my vibration is coming from? It occurs in Park/Nuetral and in gear, sometimes I can put it in Nuetral while driving and it dies down until I rev it up, it's a pretty consistant sound, Sometimes it seems to get better underload and sometimes way worse.
Thanks for any help... I've already spent thousands from shops telling me it's this or that and it's still not fixed!
The TCI Flexplate (399753) I have has no external weights on it. The first flexplate I bought that was supposed to fit had external weights and a smaller diameter crank hole.
Can Casey's Transplant rebalance my convertor or only able to tell me if it's off-balanced?
Now, about the vibration. You said that yoiu had a custom drive shaft installed. Aare you sure it was balanced correctly. Maybe they didn't get it right.
I did have him take the driveline off and rebalance it after installing it, and it was dead on.
I'm ordering a new ATI Super Damper, so hopefully that will fix the problem.
I'm new to the term "Stacked the Coverter", what does this mean?
Would it be a safe practice to unbolt my convertor with the tranny still in place and run the motor? My thoughts are this would give me a definate answer on if it's coming from the motor or the converter, but I'm not sure if there's enough room to do this without the converter sliding back into the flexplate.
Thanks again for the help!!
You should have room. I would wire the converter back so that there would be no way for it to move back into the flexplate.
One of the tell-tale sings is the bellhousing doesn't mate with the block like it should.
Disclaimer: I am NOT an expert on the subject - never done this, but have heard the stories
Oh right, I've just never heard the term "stacking the converter". I've done several convertors in the past and was aware of the 3 clicks/clunks to get it all the way seated on the input shaft. The only reason the bellhousing had the gap was due to the sleeve that TCI sent with the Flexplate (which I've since found is only for use with TH350-400 tranny). Without the sleeve it bolted up fine. Thanks for the terminology lesson, ideas, and help!
